[Moved] Improvements on VLC and 7-zip
Go to page   <<
Sat 12 Jun 2010 - 15:19
zandet2, have you tested the rev_9?
What do we do? We update the rev_7 to rev_9?
Fri 09 Jul 2010 - 15:21
Updated -Link-
Fri 09 Jul 2010 - 17:32
Sorry, forgot this topic.....
Yes, I've tested, and there is a problem:
once selected the context menu, is impossible to deactivate it (maybe the same problem of gibdemaffen -Link- ).
This happens because when the context menu are activated, the settings are written on the registry, and the x-launcher export them in 7zip_xx.reg files when X-7Zip is closed.
In a successive execution, if the context menu are deselected the settings are removed from the registry, but since there is nothing to export the launcher does not delete the correspondent old values from the 7zip_xx.reg files.
So, the bug is not in the .ini settings, but in the launcher itself.
Sat 10 Jul 2010 - 00:16
You are right.
Maybe it is better to remove the context menu support.
I don't see any solution.
Go to page   <<
