Link sponsorizzati
[Moved] Improvements on VLC and 7-zip
Vai a pagina   <<
sab 12 giu 2010 - 15:19
zandet2, have you tested the rev_9?
What do we do? We update the rev_7 to rev_9?
winPenPack Links:
Segnala software § Segnala aggiornamento § Segnala bug § Richiedi portabilizzazione § Regolamento § Aggiornamenti per wpp versione successiva § Collabora e contribuisci!
Submit software § Submit update § Submit bug § Portable request § Forum rules § Updates for the next wpp version § Collaborate and contribute!
ven 09 lug 2010 - 15:21
Danix scrisse ...
Updated -Link-
winPenPack Links:
ven 09 lug 2010 - 17:32
Sorry, forgot this topic.....
Yes, I've tested, and there is a problem:
once selected the context menu, is impossible to deactivate it (maybe the same problem of gibdemaffen -Link- ).
This happens because when the context menu are activated, the settings are written on the registry, and the x-launcher export them in 7zip_xx.reg files when X-7Zip is closed.
In a successive execution, if the context menu are deselected the settings are removed from the registry, but since there is nothing to export the launcher does not delete the correspondent old values from the 7zip_xx.reg files.
So, the bug is not in the .ini settings, but in the launcher itself.
"Farai quello che ti dico, perchè sarà tuo piacere farlo"
(Corto Maltese, Nel nome di Allah misericordioso e compassionevole)
winPenPack Links:
sab 10 lug 2010 - 00:16
You are right.
Maybe it is better to remove the context menu support.
I don't see any solution.
winPenPack Links:
Vai a pagina   <<
Moderatori: Danix, Taf, Rcs, Energy, zandet2, ZioZione, Admin
Syndicate questa discussione: rss 0.92 Syndicate questa discussione: rss 2.0 Syndicate questa discussione: RDF
