Vote for winPenPack on SourceForge! ![]() winPenPack is competing for "The July 2013 Project of the Month" on SourceForge. To vote is not difficult, is enough to have a Twitter account! [Read more..] Vote now! |
Links - Win7 - Error |
| JCL |
![]() ![]() Registered Member #39110 Joined: Sat 10 Jul 2010 - 12:54Location: Vienna, Austria Posts: 20 | hello, problems arise when dragging a link - from the 64 bit-program-directory - to wpp ! the ( working ) link uses the fallowing reference "C:\Program Files\Microsoft Games\Mahjong\Mahjong.exe" that translates wpp to $Drive\Program Files (x86)\Microsoft Games\Mahjong\Mahjong.exe don't ask why I use this example as you see the wrong directory is used Q: is this a known bug ? | ||
| LordJim60 |
![]() ![]() ![]() Registered Member #33962 Joined: Sat 18 Jul 2009 - 08:45Location: Roma Posts: 1134 ![]() | Hi JCL, I have started to use seven few days ago, and I have the same problem, that seems extended to all applications at 32bit toward the 64 bit environment. It seems that it is not possible to do a drag and drop between an application at 64 bit and one at 32 ( It seems! ), while between 32 vs 32 all work fine. For examlpe, if you try to use x-mnuCommander you should be able to use the files drag and drop functionalities because the program is at 32 bit. Let me know. Bye. --- EDIT --- sorry JCL, I have misunderstood your message. I believed that you are speaking about another problem. I will verify the problem and I will take note of the BUG [ Edited Sun 01 Aug 2010 - 18:31 ] | ||
| JCL |
![]() ![]() Registered Member #39110 Joined: Sat 10 Jul 2010 - 12:54Location: Vienna, Austria Posts: 20 | LordJim60 wrote ... sorry JCL no reason to be if you realy bother to check my post - just take a program-link that points to the 64 bit directory and drop it somewhere onto wPP - you will see ... have a good time | ||
