Sponsored Links
Translations guidelines for winPenPack Net Menu v2.x.xx
Tue 21 Dec 2010 - 00:47
To translate the winPenPack Net Menu v2.x.x interface in other languages, you just need to open one of winPenPack.xx.ini files that can be found into "winPenPack\User\winpenpack_launcher\Lang" folder with a text editor (i.e. X-SciTE, X-NotePad++) and translate in your language the single voices. Save and rename the winPenPack.xx.ini file with the suffix of translated language (i.e. winPenPack_ru.ini for Russian). All translations can be sent to the translations forum section.
[ Edited Wed 22 Dec 2010 - 01:37 ]
