![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12926 ![]() | To translate the winPenPack Net Menu v2.x.x interface in other languages, you just need to open one of winPenPack.xx.ini files that can be found into "winPenPack\User\winpenpack_launcher\Lang" folder with a text editor (i.e. X-SciTE, X-NotePad++) and translate in your language the single voices. Save and rename the winPenPack.xx.ini file with the suffix of translated language (i.e. winPenPack_ru.ini for Russian). All translations can be sent to the translations forum section. [ Modificato mer 22 dic 2010 - 01:37 ] | ||
