Using finance::quote with X-GnuCash |
| cashuser |
![]() ![]() Registered Member #39659 Joined: Sat 19 Feb 2011 - 08:59Posts: 2 | Is there a way to use finance::quote with X-GnuCash ? | ||
![]() ![]() ![]() Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 ![]() | Hi cashuser, welcome to our forum! cashuser wrote ... Is there a way to use finance::quote with X-GnuCash ? I am not a GnuCash expert, so please forgive me for any inaccuracy in what follows... As you can see in the GnuCash Manual, Finance::Quote requires Perl (or ActivePerl) already installed on the host PC, and requires to be installed itself. This excludes, at this moment, to use Finance::Quote with X-GnuCash in a portable environment. There are some portable Perl versions, but I have not tested them, so I cannot said if they could help... Surely the GnuCash Team is the best source for give you all needed informations for performing the job. Good luck! Best Regards ZioZione [ Edited Sat 19 Feb 2011 - 11:21 ] | ||
| cashuser |
![]() ![]() Registered Member #39659 Joined: Sat 19 Feb 2011 - 08:59Posts: 2 | It is no problem to get a portable version of Perl installed. The real problem is how to tell X-GnuCash the path where Perl could be found. There should be a flexible way to define this path, e.g. by using an ini-file. Is there a way to define the (relative) path to Perl ? | ||
![]() ![]() ![]() Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 ![]() | Hi cashuser, as a quick hint, you can put the Perl path in the DOS environment and then run the predefined script
X-GnuCash-folder-where-you-installed\Bin\gnucash\bin\install-fq-mods.bat
For running Finance::Quote from within X-Gnucash, please refer to the Finance::Quote and GnuCash manuals. Hope this helps! Best Regards ZioZione | ||
