Bug in winPenPack Net Menu 2.6.61 Beta 2 |
dropper |
Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | I can't install X-Software, because the "Install Software" option is disabled without the possibility to alter this status. [ Edited Mon 04 Apr 2011 - 21:29 ] | ||
Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 | Hi dropper, welcome to our forum! dropper wrote ... I can't install X-Software, because the "Install Software" option is disabled without the possibility to alter this status. the "Install Software" contextual menu item is disabled if you right-click a menu item or out of the menu, otherwise it should be enabled. Please try to right-click the category where you want to install the X-Program into, and see if "Install Software" is enabled. Let us know if it works. Best Regards ZioZione [ Edited Tue 05 Apr 2011 - 13:24 ] | ||
dropper |
Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | I find out, that at first I must highlight the menu item "winPenPack directories" in the configuration menu. Afterwards I right-click the highlighted menu item "winPenPack directories" and in the emerging contextual menu now the option "Install Software" is enabled. | ||
Lionelai |
Guest | I find out, that at first I must highlight the menu item "winPenPack directories" in the configuration menu. Afterwards I right-click the highlighted menu item "winPenPack directories" and in the emerging contextual menu now the option "Install Software" is enabled. yes, i think so. [ Edited Mon 11 Apr 2011 - 19:40 ] | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3358 | You both are right! | ||
