Bug in winPenPack Net Menu 2.6.61 Beta 2 |
| dropper |
![]() ![]() Utente registrato #39636 Registrato il: mar 15 feb 2011 - 23:47Messaggi: 165 | I can't install X-Software, because the "Install Software" option is disabled without the possibility to alter this status. [ Modificato lun 04 apr 2011 - 21:29 ] | ||
![]() ![]() ![]() Utente registrato #74 Registrato il: dom 21 gen 2007 - 11:31Provenienza: Tradate (VA) Messaggi: 3821 ![]() | Hi dropper, welcome to our forum! dropper ha scritto ... I can't install X-Software, because the "Install Software" option is disabled without the possibility to alter this status. the "Install Software" contextual menu item is disabled if you right-click a menu item or out of the menu, otherwise it should be enabled. Please try to right-click the category where you want to install the X-Program into, and see if "Install Software" is enabled. Let us know if it works. Best Regards ZioZione [ Modificato mar 05 apr 2011 - 13:24 ] | ||
| dropper |
![]() ![]() Utente registrato #39636 Registrato il: mar 15 feb 2011 - 23:47Messaggi: 165 | I find out, that at first I must highlight the menu item "winPenPack directories" in the configuration menu. Afterwards I right-click the highlighted menu item "winPenPack directories" and in the emerging contextual menu now the option "Install Software" is enabled. | ||
| Lionelai |
| Ospite | I find out, that at first I must highlight the menu item "winPenPack directories" in the configuration menu. Afterwards I right-click the highlighted menu item "winPenPack directories" and in the emerging contextual menu now the option "Install Software" is enabled. yes, i think so. [ Modificato lun 11 apr 2011 - 19:40 ] | ||
| Taf |
![]() ![]() ![]() Utente registrato #251 Registrato il: lun 22 gen 2007 - 10:12Provenienza: Buttrio (UD) Messaggi: 3373 ![]() | You both are right! ![]() | ||
