[Bug]X-Notepad++
dropper
Fri 12 Aug 2011 - 07:10
Registered Member #39636
Software name:X-Notepad++
Link winPenPack:X-Notepad++ 5.9.3 [rev12 aspell]
Bug or NOT portability motivation:Impossibility to alter permanently the language via Settings -> Preferences -> tab "General" ->section "Localization"
Software license:GNU General Public License
[ Edited Fri 12 Aug 2011 - 07:34 ]
Fri 12 Aug 2011 - 09:27
I think it is enough to change the line 54 from:
;(locale)
FileCopy=$Bin$\$AppName$\unicode\localization\%Lang%.xml|$ExeDir$\nativeLang.xml|o
to:
;(locale)
---- Communication for the wpp Team ----
@zandet2, è da un paio d'anni che non rivediamo il launcher, forse sarebbe il caso di abbandonare il doppio INI. Il problema è che il programma non riconosce la lingua di sistema.
dropper
Fri 12 Aug 2011 - 09:38
Thank you for this tip. Accordingly, I have made ​​a change in the file X-Notepad++. ini (included in the XDrive folder). Now the app works fine.
[ Edited Fri 12 Aug 2011 - 09:39 ]
