X-Firefox 8.0.1 [rev4] not jump list(task) on windows 7. thanks. |
dlusera |
Registered Member #39104 Joined: Fri 09 Jul 2010 - 12:38Posts: 37 | Recent, update to windows 7 sp1, then try X-Firefox 8.0.1 [rev4] and pinup the X-firefox, but not show jump list(task) on windows 7. I try install version firefox 8.01, that ok, has a jump list(task). I test other portable software such as ccleaner , opera usb portable all support jump list(task) on windows 7. I hope X-firefox can fix this bugs. also, other support jump list software too, I think all X-sofftware can't support jump list. Hope fix and update. thanks. many user need jump list on portable. sorry, my bad english. | ||
Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 | Hi dlusera, I don't know if I correctly understand your problem, but I use daily X-Firefox 8.0 and it supports without problems jump lists, as you can see in the attached picture. Can you explain in more details what you do and what you get (i.e. some screenshot)? Best Regards ZioZione | ||
dlusera |
Registered Member #39104 Joined: Fri 09 Jul 2010 - 12:38Posts: 37 | I test 8.0 is ok. but 8.0.1 can't , are you test this version ? thanks. My screen here: -Link- [ Edited Wed 07 Dec 2011 - 13:21 ] | ||
Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 | Hi dlusera, I tested X-FF 8.0.1 in a separate folder from 8.0 (i.e. I don't updated 8.0 to 8.0.1, but tested from scratch 8.0.1, as, I think, you have done). 8.0 manages very well the jump list, while, at first sight, 8.0.1 don't. But, after some testing (and runs), I noted that also for X-FF 8.0.1 the jump list is populated and visible. So, I think that you need some time to populate the jump list cache, but it should finally work as expected. Hope this helps. Best Regards ZioZione | ||
dlusera |
Registered Member #39104 Joined: Fri 09 Jul 2010 - 12:38Posts: 37 | OK. I try first. thanks support. | ||
dlusera |
Registered Member #39104 Joined: Fri 09 Jul 2010 - 12:38Posts: 37 | Thanks ok, now. need re-start 3 time. | ||
