JackL |
![]() ![]() Registered Member #6127 Joined: Tue 18 Sep 2007 - 16:36Posts: 68 | Hi, For some reason, I cannot open the latest gimp - it does not work if I copy it to the rev 17 launcher either... no clue what's happening - I only noticed that there is additional Lib folder in the main directory (with some ghostscript stuff) otherwise I do not know what's up... I will keep you posted if I find the bug JacL | ||
dito |
![]() ![]() ![]() Registered Member #11533 Joined: Sat 31 May 2008 - 09:32Posts: 200 | Also on my laptop with Windows XP Professional Edition SP3 X-Gimp does not start. Thanks. | ||
barta |
![]() ![]() ![]() Registered Member #4207 Joined: Tue 17 Apr 2007 - 16:50Posts: 291 ![]() | hi guys, I'm experiencing similar troubles with X-LibreOffice 3.5.0 rev8 on XP. I suspect that it's the same issue you have with X-Gimp. please, download X-LibreOffice 3.5.0 from here: -Link- ![]() and tell me if it works on your system. when I double-click tha launcher I get this message: LibreOffice 3.5 - Fatal Error The application cannot be started a file status object could not be filled is the same error you get with X-Gimp? I suspect that there's some incompatibility with XP and some X-softwares [ Edited Fri 17 Feb 2012 - 07:28 ] | ||
dito |
![]() ![]() ![]() Registered Member #11533 Joined: Sat 31 May 2008 - 09:32Posts: 200 | I enclose a picture of the error at the opening of X-LibreOffice 3.5 on my XP SP3. Ciao ![]() | ||
barta |
![]() ![]() ![]() Registered Member #4207 Joined: Tue 17 Apr 2007 - 16:50Posts: 291 ![]() | @dito that's the same error i get I suspect the X-gimp and X-libreoffice issues on xp have the same root | ||
