Sponsored Links
Vote for winPenPack on SourceForge!
winPenPack is competing for "The July 2013 Project of the Month" on SourceForge. To vote is not difficult, is enough to have a Twitter account! [Read more..]
Vote now!
[winPenPack Net Menu] Swedish translation
eson
Wed 21 Mar 2012 - 10:48
Registered Member #40310
Hi guys!
Here´s Swedish translation for your launcher attached.
I can´t make "winpenpack_sv.xml" work, because it´s ansi code. Converting to UTF-8 does not help.
Here´s the error log...
Program : winPenPackNet Version: 2.7.66.2335
Path : D:\Documents\winPenPack Net Menu
Date : 2012-03-21 09:49:56
System : Microsoft Windows 7 Ultimate
Computer :
Exception : System.Xml.XmlException
Message : Det finns ett ogiltigt tecken i den givna kodningen. Rad 6, position 18.
Data :
Trace :
vid System.Xml.XmlTextReaderImpl.Throw(Exception e)
vid System.Xml.XmlTextReaderImpl.Throw(String res, String arg)
vid System.Xml.XmlTextReaderImpl.Throw(Int32 pos, String res)
vid System.Xml.XmlTextReaderImpl.InvalidCharRecovery(Int32& bytesCount, Int32& charsCount)
vid System.Xml.XmlTextReaderImpl.GetChars(Int32 maxCharsCount)
vid System.Xml.XmlTextReaderImpl.ReadData()
vid System.Xml.XmlTextReaderImpl.ParseAttributeValueSlow(Int32 curPos, Char quoteChar, NodeData attr)
vid System.Xml.XmlTextReaderImpl.ParseAttributes()
vid System.Xml.XmlTextReaderImpl.ParseElement()
vid System.Xml.XmlTextReaderImpl.ParseElementContent()
vid System.Xml.XmlTextReaderImpl.Read()
vid System.Xml.XmlTextReader.Read()
vid winPenPackNet.Controller.DataProviderOldXML.processFilesElem(MenuComponent mnu, XmlReader Xml, Boolean isRoot)
vid winPenPackNet.Controller.DataProviderOldXML.Load()
UIMessage : Inläsning av xml-fil kunde inte slutföras på grund av ett fel
//eson
sv_winpenpacknetmenu_2766.zip
[ Edited Wed 21 Mar 2012 - 14:41 ]
eson
Wed 21 Mar 2012 - 11:47
Hi again!
I made a new .xml file. Not perfect Swedish, but working.
sv_winpenpack_xml.zip
Wed 21 Mar 2012 - 12:33
Hi eson,
first of all, welcome and thank for your translations.
I'm trying to use your first files, making a (brutal) change in the .xml substituting the character "ä" with the simple "a"; everything works correctly but.... I don't speak swedish so maybe I've created some bad words
Anyhow, since our engineer LordJim take a look at this problem, your second .xml files is well accepted and we can use it until the bug is fixed.
Thanks again!
Best regards
eson
Wed 21 Mar 2012 - 12:49
zandet2 wrote ...
Hi, zandet2!
Yes, that´s what I was thinking to.
[ Edited Wed 21 Mar 2012 - 12:49 ]
Thu 22 Mar 2012 - 21:44
Registered Member #33962
try it...
winpenpack_sv.zip
to edit the menù is better that you use the winPenPack program.
@zandet2:
per problemi di codifica utf, è meglio editare i menù direttamente dal programma anzichè con un editor.
Ciao.
[ Edited Thu 22 Mar 2012 - 21:46 ]
eson
Thu 22 Mar 2012 - 21:56
LordJim60 wrote ...
try it...
Thanks! Works fine!
Exactly what did you do to the file? UTF-8 did not work for me.
Thu 22 Mar 2012 - 22:12
I've edited the menù with the winPenPackNet program (F5 - property) and saved (CTRL-S).
After that, I've copied the winpenpack.xml as winpenpack_sv.xml
eson
Thu 22 Mar 2012 - 22:13
aha... thanks!
Fri 23 Mar 2012 - 11:14
LordJim60 wrote ...
@zandet2:
Ciao.
Ciao LordJim,
non avevo pensato a questa opzione (non sono così esperto di problematiche di codifica...).
Quello che ho riscontrato sulla base delle tue modifiche è la differente codifica del carattere in esadecimale:
E4 nella versione originale
C3 A4 nella versione modificata da te, che poi è la codifica indicata in questa pagina -Link-
Da tenere presente per eventuali situazioni simili future.
Ciao!
Fri 09 Nov 2012 - 15:19
Added the swedish translation to the new 2.8.67 version -Link-
Thank you!
P.S. Please note that there is only the translation of the list ("winpenpack_sv.xml") and not the "winPenPack.sv.ini" file.
