[winPenPack Net Menu] Swedish translationGo to page << |
| eson |
![]() ![]() ![]() Registered Member #40310 Joined: Wed 21 Mar 2012 - 09:23Posts: 7 | Danix wrote ... P.S. Please note that there is only the translation of the list ("winpenpack_sv.xml") and not the "winPenPack.sv.ini" file. Hi Danix! May I ask why you did not add my "winPenPack.sv.ini" file? Is there something wrong with it? Works just fine on my machine. //eson [ Edited Sat 10 Nov 2012 - 12:51 ] | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | I'm sorry, eson, but I had not seen! I will update the package as soon as possible. In the meantime can you check that all strings are translated? I think in new files there is some change. -- edit -- Diff to previous -Link- ![]() [ Edited Sat 10 Nov 2012 - 13:21 ] | ||
| eson |
![]() ![]() ![]() Registered Member #40310 Joined: Wed 21 Mar 2012 - 09:23Posts: 7 | Ok... I found the one new string. Here´s the updated files attached. sv_winpenpacknetmenu_2867.zip[ Edited Sat 10 Nov 2012 - 15:12 ] | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | I have updated the package -Link- ![]() Thank you for the translation! -Link- ![]() | ||
Go to page <<
