Bug in X-Gimp 2.8.0 [rev19]Go to page >> |
| dropper |
![]() ![]() Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | After the run of X-Gimp 2.8.0 [rev19] I get the following error message: http://dl.dropbox.com/u/3488658/Gimp_BUG.png | ||
| robby |
![]() ![]() Registered Member #53 Joined: Sun 21 Jan 2007 - 10:10Location: Novi Ligure Posts: 28 | Anche a me appare lo stesso messaggio di errore, se utilizzo lo strumento per aggiungere testo non riesce a caricare la lista dei font presenti sul computer... probabilmente è una conseguenza del medesimo bug. Provato con W7 Professional e anche su XP professional, entrambi aggiornati. Saluti ![]() | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | @dropper and @robby, please try X-Gimp 2.8.0 [rev20]. | ||
| dropper |
![]() ![]() Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | This link doesn't work | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Upload in progress.. Try again in a few minutes. | ||
| dropper |
![]() ![]() Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | I have tested the new version X-Gimp 2.8.0 [rev20]. And once again a dialog window with the error message occurs, which I have described with the screenshot in my original post. | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Have you tried a fresh install or an upgrade? | ||
| dropper |
![]() ![]() Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | Obviously this error message occurs only in conjunction with an upgrade. Now I have performed a fresh installation and all works fine Therefore the upgrade feature is defect. Also I doesn't get the new splash screen in case of an upgrade. [ Edited Thu 10 May 2012 - 10:32 ] | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | dropper wrote ... Therefore the upgrade feature is defect. It seems the problem concerns only the file X-Gimp_2.8.0_rev20\Bin\Gimp\lib\gimp\2.0\plug-ins\file-pdf.exe I don't know what causes the error and how to solve it. Perhaps a web search could help us. dropper wrote ... Also I doesn't get the new splash screen in case of an upgrade. Delete the gimp-splash.png image from X-Gimp_2.8.0_rev20\User\Gimp directory | ||
| zandet2 |
![]() ![]() ![]() Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 ![]() | Forse ho inteso il problema: ci sono dei plugin delle versioni precedenti incompatibili con la nuova versione di Gimp. Se eseguo x-gimp da una installazione "pulita" si avvia senza nessun problema, se invece aggiorno una versione preesistente all'avvio mi si verificano i seguenti errori: libgimpui-2.0-0.dll / errore gimp_drawable_get_thumbnail : Winicon.exe jpeg.exe libgimpui-2.0-0.dll / errore gimp_layer_new_from_pixbuf : svg.exe poppler.exe file-pdf.exe I plugin risiedono in Bin\Gimp\lib\gimp\2.0\plug-ins; nella nuova versione sono assenti, me li ritrovo ereditati da release precendenti (quali? boh). Una cosa che si potrebbe fare è inserire una sezione FirstRun che elimina questi plugin al primo avvio, insieme al vecchio splash screen:
[FirstRunOperations]
Ciao! | ||
