Bug in Firefox and Thunderbird
dropper
Tue 17 Jul 2012 - 23:16
Registered Member #39636
Firefox Portable 13.0.1, Thunderbird Portable 13.0.1 leave behind an empty folder within %LOCALAPPDATA%. There you can find the empty folders Mozilla\Firefox and Thunderbird. This is a result of a newer version of the underlying engine.
Mon 23 Jul 2012 - 20:06
Thanks for reporting, dropper.
Please, let us know if the bugs were fixed with new versions:
dropper
Mon 23 Jul 2012 - 20:38
Thank you for the fix. Now both apps works fine. Is it possible, that you explain me, how you have changed the code to reach that aim?
Mon 23 Jul 2012 - 20:47
I've added to X-Thunderbird.ini:
DirRemove=$LocalAppData$\$AppName$|e
in the [RunAfter] section
And I've added to X-Firefox.ini:
DirRemove=$LocalAppData$\Mozilla|e
In this way only the empty folders are removed from $LocalAppData$ on exit.
