dropper |
![]() ![]() ![]() Utente registrato #39636 Registrato il: mar 15 feb 2011 - 23:47Messaggi: 165 | Firefox Portable 13.0.1, Thunderbird Portable 13.0.1 leave behind an empty folder within %LOCALAPPDATA%. There you can find the empty folders Mozilla\Firefox and Thunderbird. This is a result of a newer version of the underlying engine. | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12973 ![]() | Thanks for reporting, dropper. Please, let us know if the bugs were fixed with new versions: -Link- ![]() -Link- ![]() | ||
dropper |
![]() ![]() ![]() Utente registrato #39636 Registrato il: mar 15 feb 2011 - 23:47Messaggi: 165 | Thank you for the fix. Now both apps works fine. Is it possible, that you explain me, how you have changed the code to reach that aim? | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12973 ![]() | I've added to X-Thunderbird.ini:
DirRemove=$LocalAppData$\$AppName$|e
in the [RunAfter] section And I've added to X-Firefox.ini:
DirRemove=$LocalAppData$\Mozilla|e
In this way only the empty folders are removed from $LocalAppData$ on exit. | ||
