dropper |
![]() ![]() ![]() Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | After downloading the file X-Firefox_15.0.1_rev6.zip I can't install it within the winPenPackNet menu. I get the error message:Incorrect remote setup link. Is this remote setup link stored in the file build_mozilla.ini? | ||
![]() ![]() ![]() ![]() Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 ![]() | dropper wrote ... After downloading the file X-Firefox_15.0.1_rev6.zip I can't install it within the winPenPackNet menu. I get the error message:Incorrect remote setup link. Is this remote setup link stored in the file build_mozilla.ini? Yes, my fault: the setup link was pointing directly to the italian folder... ![]() Now I've correct the release, please download and update again X-Thunderbird. Thank you! | ||
