Impossibility to install X-Thunderbird 15.0.1 [rev9] |
| dropper |
![]() ![]() Utente registrato #39636 Registrato il: mar 15 feb 2011 - 23:47Messaggi: 165 | After downloading the file X-Firefox_15.0.1_rev6.zip I can't install it within the winPenPackNet menu. I get the error message:Incorrect remote setup link. Is this remote setup link stored in the file build_mozilla.ini? | ||
| zandet2 |
![]() ![]() ![]() Utente registrato #3184 Registrato il: mar 06 mar 2007 - 11:52Provenienza: Busto Arsizio Messaggi: 3301 ![]() | dropper ha scritto ... After downloading the file X-Firefox_15.0.1_rev6.zip I can't install it within the winPenPackNet menu. I get the error message:Incorrect remote setup link. Is this remote setup link stored in the file build_mozilla.ini? Yes, my fault: the setup link was pointing directly to the italian folder... Now I've correct the release, please download and update again X-Thunderbird. Thank you! | ||
