Bug in X-Notepad++ 6.1.7 [rev15 aspell] |
dropper |
Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | In X-Notepad++ 6.1.7 [rev15 aspell] occurs the same problem as I described it in my post with the subject Bug in X-KeePass-1 1.24 [rev12]. Obviously that seems to be a fundamental failure with different X-software. It's impossible to change the language permanently. After a restart of the program the language again appears in english. Therefore I must change manually the value in the rows 40 and 41 of the file X-Notepad++.ini in the folder XDrive (I use the winPenPackNet menu) as follows: Lang=deutsch Language=de | ||
Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 | Hi dropper, dropper wrote ... In X-Notepad++ 6.1.7 [rev15 aspell] occurs the same problem as I described it in my post with the subject Bug in X-KeePass-1 1.24 [rev12]. Obviously that seems to be a fundamental failure with different X-software. It's impossible to change the language permanently. After a restart of the program the language again appears in english. Therefore I must change manually the value in the rows 40 and 41 of the file X-Notepad++.ini in the folder XDrive (I use the winPenPackNet menu) as follows: Lang=deutsch Language=de this is correct, but you can also simply comment these two rows. From this moment on, any language set from within X-Notepad++ is preserved between runs. We are thinking for a more user-friendly X-Launcher behaviour for the UI language settings, so stay tuned Best Regards ZioZione | ||
Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 | Hi dropper, from this new release X-Notepad++ does not have anymore the double .ini italian/english, so when you change the language the changes will be permanent (and you don't need to edit the .ini every time). Thank you [ Edited Wed 19 Sep 2012 - 14:50 ] | ||
dropper |
Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | Firstly thank you for the removal of the bug. But can you give me more background informations, how you have solved this problem in detail? | ||
Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 | dropper wrote ... Firstly thank you for the removal of the bug. But can you give me more background informations, how you have solved this problem in detail? Simply, in a rude way removing the double .ini and all the localization settings... Since the software does not need any pre-configuration to correctly manage the languages (on the first versions of Notepad++ you have to put manually the language file on the executable directory), now the program start by default in English, and than the user can choose the preferred language from the preferences. With this relase that selection will not overwrite by the launcher at every execution, as it happened on the previous version of X-Notepad++. | ||
