Bug in X-KeePass-1 1.24 [rev12] |
| dropper |
![]() ![]() Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | It's impossible to change the language permanently. After a restart of the program the language again appears in english. Therefore I must change manually the value in row 47 of the file X-KeePass-1.ini in the folder XDrive (I use the winPenPackNet menu). | ||
| zandet2 |
![]() ![]() ![]() Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 ![]() | Hi dropper, to solve it, you have to overwrite the X-KeePass-1.ini files with the one in the "English_users" folder (if you use the software as stand-alone), or with the one in the "XDrive\en" folder if you use the software in a pack. Otherwise, since you are using winPenPackNet, this seems to be a bit strange because it must the .swap automatically, even if you change the language of the pack. I've tried just now, and it work normally. In wich language is setted your winPenPackNet? | ||
| dropper |
![]() ![]() Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | The language of my winPenPackNet menu is set to english language. But I'm a german user. Does that mean, that the language of the program automatically switch to the language of the winPenPack menu? If so, then I have already think about a translation of the winPenPackNet menu accordingly the instructions in the Translations guidelines for winPenPack Net Menu v2.x.xx. [ Edited Tue 04 Sep 2012 - 12:12 ] | ||
