Just Manager |
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1706 | Nome del software: Just Manager Direct Link al download: -Link- versione a 32bit -Link- versione a 64 bit Dimensione File: 461 KB il file zip per la versione a 32 bit 469 KB per la versione a 64 bit Nome autore: Nikita Leontiev eMail autore: -eMail- Sito Web Autore: -Link- Descrizione: File manager piccolo ma con tutto il necessario. Comprende anche un client ftp. Portable tips how-to: Scompattare il file zip e copiare la cartella sulla chiavetta Test effettuato: EDIT BY TAF Testato! tutto OK! Portabile nativo Versione: 0.1 Alpha 26 Licenza: freeware Screenshot: [ Edited Mon 24 Dec 2012 - 12:52 ] | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1706 | Dimenticavo, traduzione italiana in corso | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3357 | Traduzione italiana già implementata da me! Ho contattato lo sviluppatore che ci ha dato il benestare a linkare il DL. la versione portable è portabile al 100% riporto qui sotto il contatto: IO: Hi, first of all my real compliments for your useful proggie! Here attached You can find my italian translation for the whole interface of JUST MANAGER. For future updates, please write me new lines will be translated and I'll help You to keep italian file updated. I'm really glad to help this project because it seems very promising! Btw, I'm in winPenPack Project staff (portable software suite) and I want to know: 1) Is Just manager really 100% portable? (stealth). Or leave some data in host PC? (registry keys/user settings and so on...). I see all settings are written in a XML file. Is that true? 2) If first question answer is YES, are you intersted to have your program shared on our website with a download link? 39 if yes, please write us a confirmation here below, because we usually share only open source proggies. Please, if you are interested, have a look to our project: -Link- Nikita Leontiev: Hello, Thanks. I'll add Italian.lng to installer if you don't mind and add you to translators mailing list. Just Manager can be installed as portable = copying files to directory, no registry entries. It will use Settings.xml in program folder. Yes, you can place JM on your website. I can add backlink on my website. Nikita Leontiev Just Manager Lead Developer PS: progetto piuttosto "acerbo" ma con ottime possibilità di sviluppo! Il developer è molto attivo e ricettivo! [ Edited Mon 24 Dec 2012 - 12:53 ] | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3357 | Just Manager Link alla pagina di download ufficiale Aggiornamento dalla versione 0.1 Alpha 26 alla 0.1 Alpha 31 Home: -Link- Direct link Portable 32bit: -Link- Direct link Portable 64bit: -Link- Risultato test: niente da segnalare - N.B. Traduzione italiana già aggiornata! [ Edited Mon 14 Jan 2013 - 13:08 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Aggiunto al database -Link- | ||
