Just Manager
sab 08 dic 2012 - 20:53
Utente registrato #9
Provenienza: Veglie
Nome del software: Just Manager
Direct Link al download: -Link- versione a 32bit -Link- versione a 64 bit
Dimensione File: 461 KB il file zip per la versione a 32 bit 469 KB per la versione a 64 bit
Nome autore: Nikita Leontiev
eMail autore: -eMail-
Descrizione: File manager piccolo ma con tutto il necessario. Comprende anche un client ftp.
Portable tips how-to: Scompattare il file zip e copiare la cartella sulla chiavetta
Test effettuato: EDIT BY TAF Testato! tutto OK! Portabile nativo
Versione: 0.1 Alpha 26
Licenza: freeware
[ Modificato lun 24 dic 2012 - 12:52 ]
sab 08 dic 2012 - 20:56
Provenienza: Veglie
Dimenticavo, traduzione italiana in corso
lun 24 dic 2012 - 12:50
Traduzione italiana già implementata da me!
Ho contattato lo sviluppatore che ci ha dato il benestare a linkare il DL.
la versione portable è portabile al 100%
riporto qui sotto il contatto:
IO:
Hi,
first of all my real compliments for your useful proggie!
Here attached You can find my italian translation for the whole interface of JUST MANAGER.
For future updates, please write me new lines will be translated and I'll help You to keep italian file updated.
I'm really glad to help this project because it seems very promising!
Btw, I'm in winPenPack Project staff (portable software suite) and I want to know:
1) Is Just manager really 100% portable? (stealth). Or leave some data in host PC? (registry keys/user settings and so on...). I see all settings are written in a XML file. Is that true?
2) If first question answer is YES, are you intersted to have your program shared on our website with a download link?
39 if yes, please write us a confirmation here below, because we usually share only open source proggies.
Please, if you are interested, have a look to our project:
Nikita Leontiev:
Hello,
Thanks.
I'll add Italian.lng to installer if you don't mind and add you to translators mailing list.
Just Manager can be installed as portable = copying files to directory, no registry entries. It will use Settings.xml in program folder.
Yes, you can place JM on your website. I can add backlink on my website.
Nikita Leontiev
Just Manager Lead Developer
PS: progetto piuttosto "acerbo" ma con ottime possibilità di sviluppo! Il developer è molto attivo e ricettivo!
[ Modificato lun 24 dic 2012 - 12:53 ]
lun 14 gen 2013 - 13:07
Just Manager
Link alla pagina di download ufficiale
Aggiornamento dalla versione 0.1 Alpha 26 alla 0.1 Alpha 31
Home: -Link-
Direct link Portable 32bit: -Link-
Direct link Portable 64bit: -Link-
Risultato test: niente da segnalare - N.B. Traduzione italiana già aggiornata!
[ Modificato lun 14 gen 2013 - 13:08 ]
mar 15 gen 2013 - 18:56
Aggiunto al database -Link-
