![]() Go to page << >> |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-7-Zip 16.02 Link winPenPack Aggiornamento dalla versione 16.01 alla 16.02 Home: -Link- ![]() Direct Link (32-bit): (non portatile) -Link- ![]() Direct Link (64-bit): (non portatile) -Link- ![]() | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-7-Zip 16.03 Link winPenPack Aggiornamento dalla versione 16.02 alla 16.03 Home: -Link- ![]() Direct Link (32-bit): (non portatile) -Link- ![]() Direct Link (64-bit): (non portatile) -Link- ![]() | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-7-Zip 16.04 Link winPenPack Aggiornamento dalla versione 16.03 alla 16.04 Home: -Link- ![]() Direct Link (32-bit): (non portatile) -Link- ![]() Direct Link (64-bit): (non portatile) -Link- ![]() | ||
sceicco |
![]() ![]() ![]() Registered Member #5022 Joined: Tue 05 Jun 2007 - 08:51Posts: 385 | X-7-Zip 18.05 Link winPenPack Aggiornamento dalla versione 16.04 alla 18.05 Home: -Link- ![]() Direct Link: (32-bit): (non portatile) -Link- ![]() Direct Link: (64-bit):(non portatile) -Link- ![]() | ||
sceicco |
![]() ![]() ![]() Registered Member #5022 Joined: Tue 05 Jun 2007 - 08:51Posts: 385 | X-7-Zip 18.06 Link winPenPack Aggiornamento dalla versione 18.05 alla 18.06 Home: -Link- ![]() Direct Link: (32-bit): (non portatile) -Link- ![]() Direct Link: (64-bit):(non portatile) -Link- ![]() | ||
sceicco |
![]() ![]() ![]() Registered Member #5022 Joined: Tue 05 Jun 2007 - 08:51Posts: 385 | X-7-Zip 19.00 Link winPenPack Aggiornamento dalla versione 18.06 alla 19.00 Home: -Link- ![]() Direct Link: (32-bit): (non portatile) -Link- ![]() Direct Link: (64-bit):(non portatile) -Link- ![]() | ||
eagleman |
![]() ![]() Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 2128 ![]() | X-7-Zip 21.05 Link winPenPack Aggiornamento dalla versione 19.00 alla 21.05 Home: -Link- ![]() Direct Link: (32-bit): (non portatile) -Link- ![]() Direct Link: (64-bit):(non portatile) -Link- ![]() | ||
eagleman |
![]() ![]() Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 2128 ![]() | X-7-Zip 21.06 Link winPenPack Aggiornamento dalla versione 21.05 alla 21.06 Home: -Link- ![]() Direct Link: (32-bit): (non portatile) -Link- ![]() Direct Link: (64-bit):(non portatile) -Link- ![]() | ||
eagleman |
![]() ![]() Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 2128 ![]() | X-7-Zip 21.07 Link winPenPack Aggiornamento dalla versione 21.06 alla 21.07 Home: -Link- ![]() Direct Link: (32-bit): (non portatile) -Link- ![]() Direct Link: (64-bit):(non portatile) -Link- ![]() | ||
eagleman |
![]() ![]() Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 2128 ![]() | Secondo l'esperto di sicurezza Kağan Çapar, tutte le versioni di 7-zip, compresa l'ultima versione 21.07, soffrono di un grave bug di sicurezza, ancora non risolto. Sfruttando i file di Aiuto di 7-zip è possibile eseguire dei comandi trascinando un file con estensione 7z nella finestra di Aiuto. Il problema risiede quindi in una errata configurazione della libreria 7z.dll. In attesa della patch, la soluzione è quella di cancellare il file 7-zip.chm pesente nella cartella C:\Program Files\7-zip (se a 64 bit) o C:\Program Files (x86)\7-zip (se a 32 bit). Se Windows chiedesse la conferma dell'operazione, accettate altrimenti vi negherà l'accesso al file. In questo modo non sarà più disponibile la guida utente, ma almeno si sarà posta una pezza (per quanto provvisoria) al problema. Si attende quindi una nuova versione del programma risolutiva del problema. | ||
