[MEDIA CATALOG]MaxLister
icemax
Wed 27 Jun 2007 - 08:02
Registered Member #194
Nome Software: MaxLister
Dimensione File: 725 KB (743254)
Nome autore: Max Bylesjö
eMail autore: -eMail-
Descrizione: MaxLister è una applicazione gratuita che permette di creare immagini virtuali
di hard disk, floppy disks, CD-ROMs , USB pen a oltri tipi di supporti di memorizzazione. Con
MaxLister, è possibile salvare file e cartelle virtuali in file MXL(database file proprietario di
MaxLister) ed è possibile successivamente effettuare la ricerca sull'intero archivio. Se non si vuole
salvare i dati sul database, il software permette di salvare i dati su file di testo normali.
Portable tips how-to: Il software viene distributo in versione no-install e in formato ZIP.
Versione:2.41
Licenza:Freeware
screenshot :
info originali :
MaxLister
MaxLister is a free application which allows you to create virtual images of harddrives, floppy disks, CD-ROMs or other removable media. This is useful if you want to keep track of that vast CD collection, a problem that a lot of people come across these days. With MaxLister, you can save any drive or folder to a .MXL-file - a database file - and later browse and search it in a Windows Explorer interface. You can import new folders/filenames from another MXL-file if you want to keep different drives in a common file. You can also batch search through a multiple number of MXL-files so that you don't have to load every single file and then repetedly search through them; looking for that particular filename. The MXL file also contains filesizes, and a comment so that you can personalize your information about the drive. If you don't want to create a viewable database, you can choose to store your drive information in a plain text file - easy to view and share with people who don't already have MaxLister. The plain text formats are separated in 3 different layouts: Collapsed, Folders only and Folders and Filenames.
Latest Version: 2.41
Release Date: January 15, 2002
Download size: 260 Kb
Setup Type: ZIP-package: unzip into optional folder and run
[ Edited Wed 27 Jun 2007 - 08:03 ]
Sat 30 Jun 2007 - 03:35
Registered Member #5089
Ho un dubbio
Chiave aggiunta:6
HKLM\SOFTWARE\Classes\.MXL
HKLM\SOFTWARE\Classes\MaxLister File
HKLM\SOFTWARE\Classes\MaxLister File\DefaultIcon
HKLM\SOFTWARE\Classes\MaxLister File\Shell
HKLM\SOFTWARE\Classes\MaxLister File\Shell\Open
HKLM\SOFTWARE\Classes\MaxLister File\Shell\Open\Command
Come le devo considerare queste voci, ininfluenti o al contrario importanti?
Così almeno mi chiarite anche "Classes" che non ho ben capito se importante o meno.
icemax
Sat 30 Jun 2007 - 09:04
Ciao ketty :
HKLM\Software\Classes
La suddetta chiave serve per registrare i componenti COM e librerie dei tipi.
in questo caso :
è la registrazione del file database proprietario di MaxLister.
le altre :
per l'integrazione nel sistema.[Shell]
cosa ne penso io :
-> la registrazione di queste chiavi non incide sulla portabilità del programma.
o sulla registrazione di dati da parte del programma.
Piccolo tutorial del registro. [ -Link- ]
[ Edited Sat 30 Jun 2007 - 09:18 ]
Sat 30 Jun 2007 - 14:49
Grassssie, anche per il tutorial
pegasocv
Tue 15 Jan 2008 - 21:07
Registered Member #6449
Anche se non è difficile da usare... non c'è una versione in italiano?
icemax
Wed 16 Jan 2008 - 08:38
ho contattato l'autore .. attendo info
Sat 08 Mar 2008 - 04:12
Come segnalato a suo tempo aggiunge 6 chiavi:
e relativi valori:
HKLM\SOFTWARE\Classes\.MXL\: "MaxLister File"
HKLM\SOFTWARE\Classes\MaxLister File\Shell\Open\Command\: "C:\TEST\MList\MaxLister.exe "%1""
HKLM\SOFTWARE\Classes\MaxLister File\Shell\: "Open"
HKLM\SOFTWARE\Classes\MaxLister File\DefaultIcon\: "C:\TEST\MList\MaxLister.exe,0"
HKLM\SOFTWARE\Classes\MaxLister File\: "MaxLister Drive Image File"
Per i motivi già specificati da Ice
ecc...
il programma è metà portabile , come usano dire Danix e Zandet
[ Edited Sat 08 Mar 2008 - 04:14 ]
