[MEDIA CATALOG]MaxLister |
| icemax |
![]() ![]() Utente registrato #194 Registrato il: dom 21 gen 2007 - 22:27Messaggi: 1371 ![]() | Nome Software: MaxLister Direct Link al download: -Link- ![]() Dimensione File: 725 KB (743254) Nome autore: Max Bylesjö eMail autore: -eMail- ![]() Sito Web Autore: -Link- ![]() Descrizione: MaxLister è una applicazione gratuita che permette di creare immagini virtuali di hard disk, floppy disks, CD-ROMs , USB pen a oltri tipi di supporti di memorizzazione. Con MaxLister, è possibile salvare file e cartelle virtuali in file MXL(database file proprietario di MaxLister) ed è possibile successivamente effettuare la ricerca sull'intero archivio. Se non si vuole salvare i dati sul database, il software permette di salvare i dati su file di testo normali. Portable tips how-to: Il software viene distributo in versione no-install e in formato ZIP. Versione:2.41 Licenza:Freeware screenshot : ![]() ![]() info originali : MaxLister MaxLister is a free application which allows you to create virtual images of harddrives, floppy disks, CD-ROMs or other removable media. This is useful if you want to keep track of that vast CD collection, a problem that a lot of people come across these days. With MaxLister, you can save any drive or folder to a .MXL-file - a database file - and later browse and search it in a Windows Explorer interface. You can import new folders/filenames from another MXL-file if you want to keep different drives in a common file. You can also batch search through a multiple number of MXL-files so that you don't have to load every single file and then repetedly search through them; looking for that particular filename. The MXL file also contains filesizes, and a comment so that you can personalize your information about the drive. If you don't want to create a viewable database, you can choose to store your drive information in a plain text file - easy to view and share with people who don't already have MaxLister. The plain text formats are separated in 3 different layouts: Collapsed, Folders only and Folders and Filenames. Latest Version: 2.41 Release Date: January 15, 2002 Download size: 260 Kb Setup Type: ZIP-package: unzip into optional folder and run [ Modificato mer 27 giu 2007 - 08:03 ] | ||
| Ketty |
![]() ![]() Utente registrato #5089 Registrato il: sab 09 giu 2007 - 02:27Messaggi: 1461 | Ho un dubbio Chiave aggiunta:6 ---------------------------------- HKLM\SOFTWARE\Classes\.MXL HKLM\SOFTWARE\Classes\MaxLister File HKLM\SOFTWARE\Classes\MaxLister File\DefaultIcon HKLM\SOFTWARE\Classes\MaxLister File\Shell HKLM\SOFTWARE\Classes\MaxLister File\Shell\Open HKLM\SOFTWARE\Classes\MaxLister File\Shell\Open\Command Come le devo considerare queste voci, ininfluenti o al contrario importanti? Così almeno mi chiarite anche "Classes" che non ho ben capito se importante o meno. | ||
| icemax |
![]() ![]() Utente registrato #194 Registrato il: dom 21 gen 2007 - 22:27Messaggi: 1371 ![]() | Ciao ketty : HKLM\Software\Classes La suddetta chiave serve per registrare i componenti COM e librerie dei tipi. in questo caso :
è la registrazione del file database proprietario di MaxLister. le altre :
per l'integrazione nel sistema.[Shell] cosa ne penso io : -> la registrazione di queste chiavi non incide sulla portabilità del programma. o sulla registrazione di dati da parte del programma. ------------------------------------------------------------------------------------------------- Piccolo tutorial del registro. [ -Link- ][ Modificato sab 30 giu 2007 - 09:18 ] | ||
| Ketty |
![]() ![]() Utente registrato #5089 Registrato il: sab 09 giu 2007 - 02:27Messaggi: 1461 | Grassssie, anche per il tutorial ![]() | ||
| pegasocv |
![]() ![]() Utente registrato #6449 Registrato il: mer 10 ott 2007 - 21:16Messaggi: 433 ![]() | Anche se non è difficile da usare... non c'è una versione in italiano? ![]() | ||
| icemax |
![]() ![]() Utente registrato #194 Registrato il: dom 21 gen 2007 - 22:27Messaggi: 1371 ![]() | ho contattato l'autore .. attendo info | ||
| Ketty |
![]() ![]() Utente registrato #5089 Registrato il: sab 09 giu 2007 - 02:27Messaggi: 1461 | Come segnalato a suo tempo aggiunge 6 chiavi: HKLM\SOFTWARE\Classes\.MXL HKLM\SOFTWARE\Classes\MaxLister File HKLM\SOFTWARE\Classes\MaxLister File\DefaultIcon HKLM\SOFTWARE\Classes\MaxLister File\Shell HKLM\SOFTWARE\Classes\MaxLister File\Shell\Open HKLM\SOFTWARE\Classes\MaxLister File\Shell\Open\Command e relativi valori: HKLM\SOFTWARE\Classes\.MXL\: "MaxLister File" HKLM\SOFTWARE\Classes\MaxLister File\Shell\Open\Command\: "C:\TEST\MList\MaxLister.exe "%1"" HKLM\SOFTWARE\Classes\MaxLister File\Shell\: "Open" HKLM\SOFTWARE\Classes\MaxLister File\DefaultIcon\: "C:\TEST\MList\MaxLister.exe,0" HKLM\SOFTWARE\Classes\MaxLister File\: "MaxLister Drive Image File" Per i motivi già specificati da Ice HKLM\SOFTWARE\Classes\.MXL ecc...è la registrazione del file database proprietario di MaxLister. ![]() il programma è metà portabile , come usano dire Danix e Zandet [ Modificato sab 08 mar 2008 - 04:14 ] | ||
