![]() Go to page >> |
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | [1] In questo topic è presente la lista degli aggiornamenti software dopo l' 11.08.2007, data di rilascio del winPenPack v3.1 IMPORTANTE: questo elenco si riferisce UNICAMENTE ai software inclusi nei packs. Pertanto, chi volesse collaborare può aggiungere in coda a questo post eventuali updates, facendo riferimento alla tabella ufficiale dei software: -Link- ![]() [2] Inoltre la lista comprenderà eventuali modifiche e bugs risolti sui software inclusi nei packs, in previsione della prossima versione di winPenPack. [ Edited Sat 08 Sep 2007 - 03:42 ] | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Update INI: X-Workrave launcher [rev3] -Link- ![]() [ Edited Sun 12 Aug 2007 - 20:47 ] | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Update INI: X-MediaPlayerClassic launcher [rev3] -Link- ![]() [ Edited Sun 12 Aug 2007 - 20:47 ] | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Update INI: X-SciTE [rev3] -Link- ![]() | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Update INI: X-Gnuplot 4.2 [rev3] -Link- ![]() | ||
alchimista |
![]() ![]() Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 ![]() | Update: Notepad++ 4.2.2 Link WinPenPack Aggiornamento dalla versione 4.2.1 alla 4.2.2 Home: -Link- ![]() Direct Link: -Link- ![]() Language: Italiano | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Update INI: X-OrbitDownloader 2.1.6 [rev3] -Link- ![]() [ Edited Thu 16 Aug 2007 - 15:19 ] | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Portabilizzato: X-AstroGrep 4.1.2 Windows 9x/2000/XP/Vista -Link- ![]() -Link- ![]() | ||
alchimista |
![]() ![]() Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 ![]() | Update: MediaInfo 0.7.5.2 Link winPenPack Aggiornamento dalla versione 0.7.5.1 alla 0.7.5.2 Home: -Link- ![]() Direct Link: -Link- ![]() | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Update INI: X-FileZilla [rev7] -Link- ![]() [ Edited Mon 20 Aug 2007 - 20:04 ] | ||
