Modifiche e aggiornamenti software da winPenPack 3.1 Go to page >> |
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | [1] In questo topic è presente la lista degli aggiornamenti software dopo l' 11.08.2007, data di rilascio del winPenPack v3.1 IMPORTANTE: questo elenco si riferisce UNICAMENTE ai software inclusi nei packs. Pertanto, chi volesse collaborare può aggiungere in coda a questo post eventuali updates, facendo riferimento alla tabella ufficiale dei software: -Link- [2] Inoltre la lista comprenderà eventuali modifiche e bugs risolti sui software inclusi nei packs, in previsione della prossima versione di winPenPack. [ Edited Sat 08 Sep 2007 - 03:42 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Update INI: X-Workrave launcher [rev3] -Link- [ Edited Sun 12 Aug 2007 - 20:47 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Update INI: X-MediaPlayerClassic launcher [rev3] -Link- [ Edited Sun 12 Aug 2007 - 20:47 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Update INI: X-SciTE [rev3] -Link- | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Update INI: X-Gnuplot 4.2 [rev3] -Link- | ||
alchimista |
Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 | Update: Notepad++ 4.2.2 Link WinPenPack Aggiornamento dalla versione 4.2.1 alla 4.2.2 Home: -Link- Direct Link: -Link- Language: Italiano | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Update INI: X-OrbitDownloader 2.1.6 [rev3] -Link- [ Edited Thu 16 Aug 2007 - 15:19 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Portabilizzato: X-AstroGrep 4.1.2 Windows 9x/2000/XP/Vista -Link- (Software) -Link- (INI) | ||
alchimista |
Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 | Update: MediaInfo 0.7.5.2 Link winPenPack Aggiornamento dalla versione 0.7.5.1 alla 0.7.5.2 Home: -Link- Direct Link: -Link- | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Update INI: X-FileZilla [rev7] -Link- [ Edited Mon 20 Aug 2007 - 20:04 ] | ||
