Aggiornamento: Notepad++Go to page << >> |
| Darklight79 |
![]() ![]() Registered Member #1005 Joined: Thu 25 Jan 2007 - 16:48Location: Cesena (FC) Posts: 111 | Notepad++ 4.6 Link winPenPack Aggiornamento dalla versione 4.5 alla versione 4.6 Home: -Link- ![]() Direct Link: -Link- ![]() Language: Italiano -Link- ![]() | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Notepad++ 4.7 Link WinPenPack Aggiornamento dalla versione 4.6 alla 4.7 Home: -Link- ![]() Direct Link: -Link- ![]() Language: Italiano | ||
| alchimista |
![]() ![]() Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 ![]() | Notepad++ 4.7.1![]() Aggiornamento dalla versione 4.7 alla 4.7.1 Home: -Link- ![]() Direct Link: -Link- ![]() Language: Italiano [ Edited Thu 03 Jan 2008 - 11:53 ] | ||
| alchimista |
![]() ![]() Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 ![]() | Notepad++ 4.7.2![]() Aggiornamento dalla versione 4.7.1 alla 4.7.2 Home: -Link- ![]() Direct Link: -Link- ![]() Language: Italiano | ||
| alchimista |
![]() ![]() Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 ![]() | Notepad++ 4.7.3![]() Aggiornamento dalla versione 4.7.2 alla 4.7.3 Home: -Link- ![]() Direct Link: -Link- ![]() Language: Italiano [ Edited Tue 08 Jan 2008 - 00:05 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Notepad++ 4.7.4 Link WinPenPack Aggiornamento dalla versione 4.7.3 alla 4.7.4 Home: -Link- ![]() Direct Link: -Link- ![]() Language: Italiano | ||
| alchimista |
![]() ![]() Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 ![]() | Notepad++ 4.7.5![]() Aggiornamento dalla versione 4.7.4 alla 4.7.5 Home: -Link- ![]() Direct Link: -Link- ![]() Language: Italiano | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Notepad++ 4.8 Link WinPenPack Aggiornamento dalla versione 4.7.5 alla 4.8 Home: -Link- ![]() Direct Link: -Link- ![]() Language: Italiano Risultato Test: Effettuano modifiche in "Configurazione-opzioni" vengono scritte le seguenti chiavi: Chiave aggiunta:4 ---------------------------------- HKLM\SOFTWARE\Classes\Notepad++_file HKLM\SOFTWARE\Classes\Notepad++_file\shell HKLM\SOFTWARE\Classes\Notepad++_file\shell\open HKLM\SOFTWARE\Classes\Notepad++_file\shell\open\command ---------------------------------- Valore aggiunto:2 ---------------------------------- HKLM\SOFTWARE\Classes\Notepad++_file\shell\open\command\: ""C:\Downloads\npp.4.8.bin\notepad++.exe" "%1"" HKLM\SOFTWARE\Classes\Notepad++_file\: "Notepad++ Document" [ Edited Wed 27 Feb 2008 - 16:48 ] | ||
| kallisto |
![]() ![]() Registered Member #2938 Joined: Fri 23 Feb 2007 - 00:09Posts: 50 | già..comunque ho provato a cancellare la chiave e a riaprire npp e la chiave non ricompare..giusto per la cronaca le uniche voci rimaste sono in MUIcache (quindi programmi aperti di recente) e FileExts sotto la voce def. (file del mugen) in OpenWithList... sinceramente non mi è chiaro perchè accada ciò,visto che ho aperto vari tipi di file e solamente con i file def sembra lasciare tracce una volta cancellata la chiave Notepad++ file.. | ||
| alchimista |
![]() ![]() Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 ![]() | Ciao Kallisto, purtroppo devo confermare quanto rilevato da Rcs, anche io ho cancellato le chiavi sopra segnalate (come hai fatto tu), ma al seguente avvio e dopo alcuni cambiamenti nelle opzioni quelle chiavi sono ricomparse. | ||
