[GPL] [Not portable][Internet] Free Download Manager Go to page << >> |
deep |
Registered Member #7 Joined: Sat 20 Jan 2007 - 20:57Posts: 568 | Ho capito, grazie. | ||
Darklight79 |
Registered Member #1005 Joined: Thu 25 Jan 2007 - 16:48Location: Cesena (FC) Posts: 111 | Ho provato ad utilizzare Free Download Manager. Aggiunge le seguenti chiavi di registro: HKEY_CURRENT_USER\Software\FreeDownloadManager.ORG HKEY_CURRENT_USER\Software\FreeDownloadManager.ORG\Free Download Manager HKEY_CURRENT_USER\Software\FreeDownloadManager.ORG\Free Download Manager\Settings HKEY_CURRENT_USER\Software\FreeDownloadManager.ORG\Free Download Manager\Settings\Monitor HKEY_CURRENT_USER\Software\FreeDownloadManager.ORG\Free Download Manager\Settings\Update HKEY_CURRENT_USER\Software\FreeDownloadManager.ORG\Free Download Manager\Settings\View HKEY_CURRENT_USER\Software\FreeDownloadManager.ORG\Free Download Manager\Settings\View\Loc HKEY_CURRENT_USER\Software\FreeDownloadManager.ORG\Free Upload Manager HKEY_CURRENT_USER\Software\FreeDownloadManager.ORG\Free Upload Manager\Settings HKEY_CURRENT_USER\Software\FreeDownloadManager.ORG\Free Upload Manager\Settings\Integration Se le cancello vengono ricreate. | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Darklight79 hai proprio ragione Urge testing.... e portabilizzazione.... [ Edited Sat 01 Sep 2007 - 17:44 ] | ||
deep |
Registered Member #7 Joined: Sat 20 Jan 2007 - 20:57Posts: 568 | Ma succede anche creando la versione portatile direttamente dal programma con la funzione "Create portable version"? | ||
Darklight79 |
Registered Member #1005 Joined: Thu 25 Jan 2007 - 16:48Location: Cesena (FC) Posts: 111 | A me succede anche in questo caso. | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | deep wrote ... Ma succede anche creando la versione portatile direttamente dal programma con la funzione "Create portable version"? Come ben sai il concetto di "portable" varia molto da caso a caso....vedi deepburner portable (si fa per dire) ... [ Edited Sat 01 Sep 2007 - 19:50 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Il resume dei download non è supportato nel passaggio da un drive all'altro. Non portatile. | ||
Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 | Danix wrote ... Il resume dei download non è supportato nel passaggio da un drive all'altro. Non portatile. Ciao Danix, prima di darlo per spacciato, se il programma è veramente utile, questo problema si potrebbe sistemare con il programmino di Ice -Link- . Che ne dici? Cordialmente ZioZione | ||
Energy |
Registered Member #1118 Joined: Fri 26 Jan 2007 - 12:09Location: Treviso Posts: 1093 | Aggiornamento... Free Download Manager 3.0 build 848 Aggiornamento dalla versione 2.5 alla 3.0 Home: -Link- Direct link: (not portable) -Link- Risultato test: (sulla versione da loro definita portabile)
Non ho provato ad adattarlo alla struttura di winPenPack, ma nel complesso direi che è portabilizzabile. Sposto in Richieste di portabilizzazione | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Energy, il problema è il resume dei file. Hai controllato se in questa versione è supportato? | ||
