Aggiornamento: X-VirtualDub Go to page >> |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-VirtualDub 1.7.3 released Link winPenPack aggiornamento dalla versione 1.7.2 alla versione 1.7.3 Home: -Link- Direct Link: not portable -Link- [ Edited Sun 02 Sep 2007 - 01:43 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-VirtualDub 1.7.4 (stable) Link winPenPack aggiornamento dalla versione 1.7.3 alla versione 1.7.4 (stable) Home: -Link- Direct Link: not portable -Link- [ Edited Sat 29 Sep 2007 - 23:20 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-VirtualDub 1.7.5 (stable) Link winPenPack aggiornamento dalla versione 1.7.4 (stable) alla versione 1.7.5 (stable) Home: -Link- Direct Link: not portable -Link- [ Edited Sun 14 Oct 2007 - 11:40 ] | ||
alchimista |
Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 | X-VirtualDub 1.7.6.28292 aggiornamento dalla versione 1.7.5.28225 alla versione 1.7.6.28292 Home: -Link- Direct Link: not portable -Link- [ Edited Sun 14 Oct 2007 - 13:55 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-VirtualDub 1.7.7.28312 Link winPenPack aggiornamento dalla versione 1.7.6.28292 alla versione 1.7.7.28312 Home: -Link- Direct Link: not portable -Link- [ Edited Fri 14 Dec 2007 - 08:54 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-VirtualDub v1.7.8 (stable) Link winPenPack aggiornamento dalla versione 1.7.7.28312 alla v1.7.8 (stable) Home: -Link- Direct Link: not portable -Link- [ Edited Fri 15 Feb 2008 - 08:21 ] | ||
sceicco |
Registered Member #5022 Joined: Tue 05 Jun 2007 - 08:51Posts: 385 | VirtualDub 1.7.8 Build 28346 Stable Link winPenPack -Link- aggiornamento dalla versione 1.7.7.28312 alla v1.7.8 Build 28346 Stable Home: -Link- Direct Link: not portable i386 -Link- Direct Link: not portable AMD64 -Link- P.S. Ho trovato utile segnalare le 2 versioni! [ Edited Fri 15 Feb 2008 - 01:23 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Scusa ma non è la stessa versione (e build) già segnalata correttamente da RCS? | ||
sceicco |
Registered Member #5022 Joined: Tue 05 Jun 2007 - 08:51Posts: 385 | Ho voluto evidenziare le 2 differenti versioni,a tal proposito chiedo se si possano postare entrambe nel download. Mi scuso sopratutto con rcs per aver rieditato il post, ma mi pareva utile sottolineare le due versioni per le diverse cpu. [ Edited Fri 15 Feb 2008 - 01:39 ] | ||
Darklight79 |
Registered Member #1005 Joined: Thu 25 Jan 2007 - 16:48Location: Cesena (FC) Posts: 111 | X-VirtualDub 1.8.1 Stable Link winPenPack Aggiornamento dalla versione 1.7.8 Build 28346 Stable alla versione 1.8.1 Stable Home: -Link- Direct Link: not portable i386 -Link- Direct Link: not portable AMD64 -Link- [ Edited Sat 28 Jun 2008 - 21:21 ] | ||
