X-Opera Launcher
Wed 05 Sep 2007 - 23:14
Ecco una prima versione del super richiesto launcher per Opera.
Download X-Opera Launcher 1.1 [rev1]: -Link-
; Ini file [rev1] - Author: Danix (winpenpack@gmail.com) - Date: 05.09.2007
; X-Opera Launcher is released under Freeware License.
AppName=Opera
[FileToRun]
[Environment]
OperaDownloadDir=$Download$\$AppName$
[Functions]
; Locale - rimozione lingue tranne l'Italiano (da attivare)
;DirCopy=$ExeDir$\locale\it|$ExeDir$\locale_it\it
;DirRemove=$ExeDir$\locale
;DirMove=$ExeDir$\locale_it|$ExeDir$\locale
DirCreate=%OperaDownloadDir%
FileCopy=$Home$\$AppName$\operadef6.ini|$ExeDir$\operadef6.ini|o
FileCopy=$Home$\$AppName$\opera6.ini|$ExeDir$\profile\opera6.ini|o
[RunAfter]
FileCopy=$ExeDir$\operadef6.ini|$Home$\$AppName$\operadef6.ini|o
FileCopy=$ExeDir$\profile\opera6.ini|$Home$\$AppName$\opera6.ini|o
DirRemove=@TempDir@\Opera
; Backup (da attivare)
;DirMove=$Backup$\$AppName$\backup_2|$Backup$\$AppName$\backup_3|o
;DirMove=$Backup$\$AppName$\backup_1|$Backup$\$AppName$\backup_2|o
;DirCopy=$ExeDir$\profile|$Backup$\$AppName$\backup_1\profile
;FileCopy=$ExeDir$\operadef6.ini|$Backup$\$AppName$\backup_1
[WriteToIni=$ExeDir$\operadef6.ini]
User Prefs|Cache Style File=$ExeDir$\Styles\cache.css
User Prefs|Dir Style File=$ExeDir$\Styles\dir.css
User Prefs|Drives Style File=$ExeDir$\Styles\drives.css
User Prefs|History Style File=$ExeDir$\Styles\history.css
User Prefs|Plugins Style File=$ExeDir$\Styles\plugins.css
User Prefs|Language File=$ExeDir$\locale\it\it.lng
User Prefs|WML CSS File=$ExeDir$\Styles\wml.css
User Prefs|OPF CSS File=$ExeDir$\Styles\opf.css
User Prefs|CSR CSS File=$ExeDir$\Styles\csr.css
User Prefs|About Style File=$ExeDir$\Styles\About.css
User Prefs|MIME Style File=$ExeDir$\Styles\mime.css
User Prefs|Info CSS File=$ExeDir$\Styles\info.css
User Prefs|Language Codes File=$ExeDir$\lngcode.txt
User Prefs|IM Style File=$ExeDir$\Styles\im.css
User Prefs|Certificate Info CSS File=$ExeDir$\styles\certinfo.css
User Prefs|Plugin Path=$ExeDir$\Program\Plugins;
Local CSS Files|File 1=$ExeDir$\styles\user\textonly.css
Local CSS Files|File 2=$ExeDir$\styles\user\nostalgia.css
Local CSS Files|File 3=$ExeDir$\styles\user\accessibility.css
Local CSS Files|File 4=$ExeDir$\styles\user\imageandlinkonly.css
Local CSS Files|File 5=$ExeDir$\styles\user\contrastwb.css
Local CSS Files|File 6=$ExeDir$\styles\user\contrastbw.css
Local CSS Files|File 7=$ExeDir$\styles\user\hidenonlinkimages.css
Local CSS Files|File 9=$ExeDir$\styles\user\disabletables.css
Local CSS Files|File 10=$ExeDir$\styles\user\showstructure.css
Local CSS Files|File 11=$ExeDir$\styles\user\debugwithoutline.css
Adv User Prefs|Plugin ignore file=$ExeDir$\plugin-ignore.ini
System|Multi User=0
Java|Opera Classpath=$ExeDir$\Classes\Opera.jar
Java|Security Policy=$ExeDir$\Classes\Opera.policy
VoiceXML|voicexmlplugin=$ExeDir$\vxmplugin.dll
VoiceXML|library location=$ExeDir$\
VoiceXML|resources location=$ExeDir$\
Install|MAINDIR=$ExeDir$\
[WriteToIni=$ExeDir$\profile\opera6.ini]
User Prefs|Opera Directory=$ExeDir$\profile
User Prefs|Download Directory=%OperaDownloadDir%
User Prefs|Hot List File Ver2=$ExeDir$\profile\opera6.adr
User Prefs|Cache Directory4=@TempDir@\Opera\cache4
User Prefs|Operator Cache Directory4=@TempDir@\Opera\opcache
User Prefs|Temporary Download Directory=@TempDir@\Opera\cache4\temporary_download
User Prefs|Show Default Browser Dialog=0
User Prefs|Startup Type=4
Mail|Mail Root Directory=$ExeDir$\mail
Saved Settings|Open Dir=%OperaDownloadDir%
Saved Settings|Save Dir=%OperaDownloadDir%
Disk Cache|Empty On Exit=1
[WriteToIni=$ExeDir$\spellcheck.ini]
Spell check|Spell check engine=$ExeDir$\spellcheck.dll
; Mail on server
;[WriteToIni=$ExeDir$\mail\accounts.ini]
;Account1|Leave On Server=1
[StringReplace=$ExeDir$\profile\opera6.ini]
Button Set|\skin==$ExeDir$
Toolbar Configuration|profile==$ExeDir$\
[WriteToReg=$Home$\$AppName$\$AppName$_1.reg]
MainKey=HKEY_CURRENT_USER\Software\Opera Software
[WriteToReg=$Home$\$AppName$\$AppName$_2.reg]
MainKey=HKEY_LOCAL_MACHINE\SOFTWARE\Clients\Mail\Opera
[WriteToReg=$Home$\$AppName$\$AppName$_3.reg]
MainKey=HKEY_LOCAL_MACHINE\SOFTWARE\Clients\News\Opera
[WriteToReg=$Home$\$AppName$\$AppName$_4.reg]
MainKey=HKEY_LOCAL_MACHINE\SOFTWARE\Clients\StartMenuInternet\Opera.exe
[RunBefore]
RegEdit=$Home$\$AppName$\$AppName$_1.reg;$AppName$_2.reg;$AppName$_3.reg;$AppName$_4.reg
[Options]
DeleteTemp=true
RunWait=true
ShowSplash=false
WriteLog=false
[SplashScreen]
Image=
Title=
TimeOut=1500
[ Edited Sun 11 May 2008 - 01:03 ]
sceicco
Thu 06 Sep 2007 - 22:14
Registered Member #5022
Mitico Danix, volevo chiederti se nel launcher da te compilato hai tenuto conto di questi 2 passaggi che ho trovato sul sito della versione - Opera@USB, e precisamente:
Riporto come scritto
Opera - FAQ
Does permanent access damage the USB stick?
To safe livetime of the USB Device and to increase speed of Opera, the cache-directory is on the harddisk (at Windows temp)
the Cache was cleared after normal close of Opera, so there is no data left.
I like to use the Sessions function ?
The Sessions function was disabled (Continue from last time) so Opera don't always writes the actual state to the stick
To activate the "Continue from last time" / Sessions - function , you have only to delete the sessions file in the operausb\profile\ directory - thats all !
Ciao!
Thu 06 Sep 2007 - 22:22
sceicco wrote ...
Ovvio
La cache viene salvata in una directory temporanea anzichè nel profilo personale per poi esser cancellata alla chiusura dell'applicazione.
Esattamente in C:\Documents and Settings\Nome_Utente\Impostazioni locali\Temp\Opera
La cartella "Opera" rimane su Hd vuota, ma volendo potrei inserire un'istruzione per eliminarla.
[rev2] Linea 38, aggiungere:
(ho aggiornato il launcher)
sceicco wrote ...
Non ho disabilitato invece questa funzione. Non ne ero neanche a conoscenza. Che sarebbe? Se si elimina il "sessions file" non si crea il profilo?
[ Edited Sun 23 Sep 2007 - 17:10 ]
alexcyber
Mon 04 Feb 2008 - 15:20
Registered Member #5886
ciao Danix, da molto tempo uso senza problema il tuo launcher per Opera e di questo ti ringrazio, avrei però bisogno di un aiuto, è possibile modificare il file INI(magari in maniera reversibile) per fare in modo che alla chiusura di Opera la cache non venga cancellata e venga ripristinata al successivo avvio del browser?
stò usando una flat basata sui mega scaricati in up/down e mi farebbe comodo che il broswer utilizzi la cache, riducendo così il traffico di dati scambiati....
grazie
[ Edited Mon 04 Feb 2008 - 15:21 ]
Wed 06 Feb 2008 - 00:51
La soluzione migliore sarebbe quella di spostare la cache in \User (anzichè lasciarla in %temp%) ed evitare che venga cancellata alla chiusura del browser.
Prova a sostituire queste righe di codice in X-Opera.ini e fammi sapere..
(righe 104, 105, 106)
User Prefs|Cache Directory4=$Home$\$AppName$\cache4
User Prefs|Operator Cache Directory4=$Home$\$AppName$\opcache
User Prefs|Temporary Download Directory=$Home$\$AppName$\cache4\temporary_download
(riga 112)
Disk Cache|Empty On Exit=0
alexcyber
Sat 09 Feb 2008 - 10:56
(riga 112)
funziona perfettamente! , forse sarebbe da valutare se inserire queste modifiche nel launcher definitivo.....
grazie
Sat 09 Feb 2008 - 11:29
Ho spostato la cache in %temp% proprio per evitare un'eccessiva scrittura nella cartella del programma, e quindi su USB Pen.
Potrei pensare però a un'impostazione alternativa nell'INI da cambiare facilmente..
alexcyber
Sat 09 Feb 2008 - 11:40
considerando che molti utenti(io compreso) usano x-software su desktop sarebbe un' idea Ottima!
Sun 11 May 2008 - 01:01
[rev4]
Download: -Link-
  1. Aggiunto supporto a GNU Aspell (correttore ortografico).
    (Copiare GNU Aspell e relativi dizionari in X-Opera\Lib\Aspell. Per comodità è possibile copiare la cartella \Lib\Aspell dal pacchetto di X-Notepad++).
  2. Fix: i percorsi assoluti dei widgets non venivano aggiornati, con conseguente perdita della portatilità cambiando drive o percorso.
[ Edited Sun 11 May 2008 - 01:16 ]
Mon 04 Aug 2008 - 18:11
[rev5]
Download: -Link-
  1. Risolti bug memorizzazione skin e bug correttore ortografico (aspell) per Opera 9.51 -Link-
  2. Aggiunta opzione per settare la cache nella directory $Temp$ (impostazione consigliata per l'utilizzo di Opera su USB Pen).
    Attivare:
    ;Cache4=$Temp$\cache4
    ;OpCache=$Temp$\opcache
    ;TemporaryDownloadDir=$Temp$\cache4\temporary_download
    e disattivare:
    Cache4=$Home$\$AppName$\cache4
    OpCache=$Home$\$AppName$\opcache
    TemporaryDownloadDir=$Home$\$AppName$\cache4\temporary_download
  3. Aggiunte opzioni per la localizzazione:
    Opera_lang=it (de, fr, etc.. interfaccia del programma nella lingua impostata)
    Aspell_lang=it (de, fr, etc.. correttore ortografico nella lingua impostata)
    Attivare:
    ;(locale)
    ;User Prefs|Language File=$ExeDir$\locale\%Opera_lang%\%Opera_lang%.lng
  4. Rimozione di tutte le lingue tranne quella impostata.
    Attivare:
    ;(remove all languages except your language)
    ;DirCopy=$ExeDir$\locale\%Opera_lang%|$ExeDir$\locale_%Opera_lang%\%Opera_lang%
    ;DirMove=$ExeDir$\locale_%Opera_lang%|$ExeDir$\locale
