![]() Go to page >> |
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Ecco una prima versione del super richiesto launcher per Opera. ![]() Download X-Opera Launcher 1.1 [rev1]: -Link- ![]()
[ Edited Sun 11 May 2008 - 01:03 ] | ||
sceicco |
![]() ![]() ![]() Registered Member #5022 Joined: Tue 05 Jun 2007 - 08:51Posts: 385 | Mitico Danix, volevo chiederti se nel launcher da te compilato hai tenuto conto di questi 2 passaggi che ho trovato sul sito della versione - Opera@USB, e precisamente: Riporto come scritto Opera - FAQ Does permanent access damage the USB stick? To safe livetime of the USB Device and to increase speed of Opera, the cache-directory is on the harddisk (at Windows temp) the Cache was cleared after normal close of Opera, so there is no data left. I like to use the Sessions function ? The Sessions function was disabled (Continue from last time) so Opera don't always writes the actual state to the stick To activate the "Continue from last time" / Sessions - function , you have only to delete the sessions file in the operausb\profile\ directory - thats all ! Ciao! | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | sceicco wrote ... Does permanent access damage the USB stick? To safe livetime of the USB Device and to increase speed of Opera, the cache-directory is on the harddisk (at Windows temp) the Cache was cleared after normal close of Opera, so there is no data left. Ovvio ![]() La cache viene salvata in una directory temporanea anzichè nel profilo personale per poi esser cancellata alla chiusura dell'applicazione. Esattamente in C:\Documents and Settings\Nome_Utente\Impostazioni locali\Temp\Opera La cartella "Opera" rimane su Hd vuota, ma volendo potrei inserire un'istruzione per eliminarla. ------------------------------------------------ [rev2] Linea 38, aggiungere:
DirRemove=@TempDir@\Opera
(ho aggiornato il launcher) ------------------------------------------------ sceicco wrote ... Non ho disabilitato invece questa funzione. Non ne ero neanche a conoscenza. Che sarebbe? Se si elimina il "sessions file" non si crea il profilo?I like to use the Sessions function ? The Sessions function was disabled (Continue from last time) so Opera don't always writes the actual state to the stick To activate the "Continue from last time" / Sessions - function , you have only to delete the sessions file in the operausb\profile\ directory - thats all ! [ Edited Sun 23 Sep 2007 - 17:10 ] | ||
alexcyber |
![]() ![]() ![]() Registered Member #5886 Joined: Thu 30 Aug 2007 - 00:24Posts: 149 | ciao Danix, da molto tempo uso senza problema il tuo launcher per Opera e di questo ti ringrazio, avrei però bisogno di un aiuto, è possibile modificare il file INI(magari in maniera reversibile) per fare in modo che alla chiusura di Opera la cache non venga cancellata e venga ripristinata al successivo avvio del browser? stò usando una flat basata sui mega scaricati in up/down e mi farebbe comodo che il broswer utilizzi la cache, riducendo così il traffico di dati scambiati.... grazie [ Edited Mon 04 Feb 2008 - 15:21 ] | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | La soluzione migliore sarebbe quella di spostare la cache in \User (anzichè lasciarla in %temp%) ed evitare che venga cancellata alla chiusura del browser. Prova a sostituire queste righe di codice in X-Opera.ini e fammi sapere.. (righe 104, 105, 106)
User Prefs|Cache Directory4=$Home$\$AppName$\cache4
(riga 112)
Disk Cache|Empty On Exit=0
alexcyber |
![]() ![]() ![]() Registered Member #5886 Joined: Thu 30 Aug 2007 - 00:24Posts: 149 | Danix wrote ... La soluzione migliore sarebbe quella di spostare la cache in \User (anzichè lasciarla in %temp%) ed evitare che venga cancellata alla chiusura del browser. Prova a sostituire queste righe di codice in X-Opera.ini e fammi sapere.. (righe 104, 105, 106)
(riga 112)
funziona perfettamente! ![]() grazie | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | forse sarebbe da valutare se inserire queste modifiche nel launcher definitivo..... Ho spostato la cache in %temp% proprio per evitare un'eccessiva scrittura nella cartella del programma, e quindi su USB Pen.Potrei pensare però a un'impostazione alternativa nell'INI da cambiare facilmente.. | ||
alexcyber |
![]() ![]() ![]() Registered Member #5886 Joined: Thu 30 Aug 2007 - 00:24Posts: 149 | Potrei pensare però a un'impostazione alternativa nell'INI da cambiare facilmente.. considerando che molti utenti(io compreso) usano x-software su desktop sarebbe un' idea Ottima! | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | [rev4] Download: -Link- ![]()
[ Edited Sun 11 May 2008 - 01:16 ] | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | [rev5] Download: -Link- ![]()
