wpp essentials doesn't fit on 256mb stick |
| ralf |
![]() ![]() Utente registrato #6149 Registrato il: mer 19 set 2007 - 15:21Messaggi: 4 | Hi everybody, thanks a lot for developing this great tool!!! Trying to install the new 3.2 essential english language version to my 256mb stick, I had to realize that it doesn't fit. Is that really true or am I making something wrong during the installation? Best regards Ralf | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | Welcome to winPenPack The required space on Pen Drive USB for wPP essential (english-multilingual version) is around 198 Mb... Did you download the setup.exe or the .zip archive+language_pack.zip? [ Modificato mer 19 set 2007 - 16:13 ] | ||
| ralf |
![]() ![]() Utente registrato #6149 Registrato il: mer 19 set 2007 - 15:21Messaggi: 4 | Hi Danix, I've tried all of these: The setup-exe says during installation that it could not install to the stick, because it needs app. 278mb (or so). Then I've installed the zip-file to the stick (197mb on the stick), but when I unzipp the language file it says 94mb - and trying to copy it to the stick ends after a while eventually with 'no more space available' Ralf | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | I'm sorry! I have to correct the download page ![]() Suggestion: extract the zipped file+language pack on your hd (in 2 different folders) >> search for "locale" on language pack >> remove all lang you don't need >> overwrite the winPenPack (italian) main directory with the (small now!) language pack >> copy winPenPack on your USB Pen [ Modificato mer 19 set 2007 - 16:58 ] | ||
| ralf |
![]() ![]() Utente registrato #6149 Registrato il: mer 19 set 2007 - 15:21Messaggi: 4 | Thanks! I'll try tomorrow and let you know..... Bye Ralf | ||
| ralf |
![]() ![]() Utente registrato #6149 Registrato il: mer 19 set 2007 - 15:21Messaggi: 4 | Hi Danix, looks OK for me! As you said, I've deleted all other language files (besides the 'de'-files) in all the several 'locale'-folders I found in the language pack, copied the pack to the main folder and had only 198mb left for the stick - great!!! Thanks a lot for your help! Bye Ralf | ||
