andLinux
Peter G
dom 20 apr 2008 - 20:19
Utente registrato #5718
Registrato il: mar 14 ago 2007 - 21:38
AndLinux is a Windows program that allows to run Linux Applications (on ms windows maschines).
website (www.andlinux.org): -Link-
For me - as a non-prgrammer - it look difficult to make that portable.
gio 16 apr 2009 - 02:34
Utente registrato #5089
andLinux
La cosa è interessante, mi riprometto sempre di trovare il tempo ma...
Comunque, basandomi esclusivamente sulle caratteristiche richieste:
OS: Windows 2000 / XP / 2003 / Vista (currently only the 32-bit versions are supported)
Memory: at least 128 MB (192 MB or more is recommended). Note that you should have enough memory left for Windows (at least 128 MB for Windows 2000 / XP / 2003; at least 512 MB for Windows Vista)!
Hard disk space: 2.5 GB (XFCE version) / 4.5 GB (KDE version). Note that you need an NTFS file system (which is default since Windows 2000) because you can't create files larger than 2 GB on FAT(32) file systems!
A good internet connection (to be able to install further applications via apt-get / Synaptic)
Some basic Linux skills to proceed once andLinux is installed
credo che la sezione più appropriata sia Tips & Tricks - Supporto off topic
