KOffice
JackL
gio 02 ott 2008 - 17:43
Utente registrato #6127
Registrato il: mar 18 set 2007 - 16:36
Hi, I know that it's in Beta still however probably you can find it interesting enough to portabilize it - it contains among others full office suite and graphic stuff - I even dare to claim it can replace openoffice + gimp and all in consistent look&feel - after all with Qt 4 undernith - it is available for 3 main platforms which make it prety handfull - you use one tool on every platform...
only problem I see is that it can be too complex - but with new x-louncher2 - who knows? :]
Cheers
JackL
ven 03 ott 2008 - 08:42
Hi JackL,
Yeah, IMHO is too early to consider Koffice as a possible substitute of OpenOffice.
For windows at the moment i able to find only a Alpha10 release!
In any case is better to wait for a more stable release.
if someone wants to have a look...
Anyway, many thanks for Your info.
ven 03 ott 2008 - 09:00
Hi JackL,
Taf preceeded me for few minutes
Please remember that it is always better to add a link regarding the signaled software...
Thank you for your support!
Best Regards
P.S. Taf, latest release is 2.0 beta1, that can be found here -Link- (there is a Windows Installer, it should work, but I don't have already tested...)
[ Modificato ven 03 ott 2008 - 09:06 ]
ven 03 ott 2008 - 09:51
ZioZione ha scritto ...
sorry for my old link! Thanks Zio!
ven 03 ott 2008 - 10:39
Taf® ha scritto ...
Hi Taf,
don't worry, maybe YOU are right... my link is taken directly from KOffice site, while yours is from KDe for Windows... Until test, I dont know what is the *REAL* latest one...
Best Regards
JackL
ven 03 ott 2008 - 13:36
Yes - that is unclear a bit... but worth of observation though - I'm impressed by krita and some ofit's functionality (raw processing, 32bit color deth, artistic brushes/tools imitation algorythm....)
If all suite is on this level of innovation - that would change the scores...
cheers
JackL
