UK's Kalender |
icemax |
Utente registrato #194 Registrato il: dom 21 gen 2007 - 22:27Messaggi: 1371 | Ciao..a tutti propongo UK's Kalender Ottimo calendario/appuntamenti/ToDo ottimo sostituto a Essential pim(NON molto stabile) contro : manca la rubrica (!peccato") potete scaricarlo da qui : -------------------------------------------------------------------------------- in italiano: -Link- home page :http://www.8ung.at/ukrebs/ -------------------------------------------------------------------------------- licenza : assolutamente free -------------------------------------------------------------------------------- caratteristiche : What "UK's Kalender" can do * Automatic saving Any changes to the database are automatically and immediately saved to disk. On every program start, a backup copy of your data file is created. * Unlimited Undo and Redo Most changes can be undone and also repeated. * Minimize to the system tray "UK's Kalender" minimizes into the system tray (the area next to the system clock). * Network support "UK's Kalender" supports a shared event file, where every user can enter events that'll show up in each other user's calendar. For using the network functions it is neither required to install special server software nor to keep the computer with the shared event file permanently running. "UK's Kalender" will synchronize the local event file as soon as the shared event file is accessible. * Repeating events There are lots of possibilities for entering repeating events, e.g. hourly, every three days, monthly, every first tuesday of the month or even every friday the 13th. * Forewarn time and snooze function Each event can be assigned a user defined forwarn time in the range from one minute to several weeks. In the reminder dialog you can enter a time after that you'll be reminded again. Alternatively you can choose to be reminded again a certain time before the event. * Multi day events Events can have a duration from one minute to several days (or no duration at all, but just a start date). * Event categories and templates Events can be organized into categories, e.g. "Doctor", "Meeting", "Party" and so on. Each category is assigned a template of settings, including repetition rate and forewarn time. * Acoustic reminders You can choose to be reminded of an event with a WAV file of your choice. * Event driven program execution and document opening Documents or programs can be attached to an event. This is very handy for e.g. regular backup purposes. * Marking and hiding events Special events may be either color marked or hidden. * Four event views Events can be displayed in week-, fortnight-, month- or year-view. * Tooltips for events and todos If you stop the mouse over a calendar date or a todo, extended info is shown for the events and todos. * Alarms can be deativated Alarms may be deactivated all at once, so your game, film etc. won't be interrupted. * Highly configurable display for events and todos All views can easily be configured to present the information just the way you want. * Search and filter functions You can search for and filter out your events using keywords, categories, event states or date ranges. The filter function directly affects all output functions, so you can easily create e. g. a calendar only containing birthdays. * Clipboard support Events and todos can be copied to the clipboard and may be pasted back to any word processor or "UK's Kalender" itself. * Export to HTML- and CSV-format Events and todos can be exported to HTML-format in different views. With this you can easily print your dates and todos. Export to CSV-format allows the transfer of your data to a spreadsheet program. All activated filter options are applied to the output. * Holidays Holidays for Gemany, Italy, France, UK, Sweden, Norway, Finland, Czech Republic, Poland, Israel, Canada and the USA can be displayed. What "UK's Kalender" can't do * Import and export from or to other calendar programs "UK's Kalender" has a proprietary file format. Neither does it understand the file format of other applications nor does it support the export of foreign calendar formats. * Printing Direct printing from "UK's Kalender" is not supported. Nevertheless you can export all your data into a HTML file and print your calendar from any web browser. -------------------------------------------------------------------------------- provatelo ! c.i.a.o. [ Modificato mer 11 mar 2009 - 01:50 ] | ||
Ketty |
Utente registrato #5089 Registrato il: sab 09 giu 2007 - 02:27Messaggi: 1461 | Nome del software: UK's Kalender Direct Link al download: versione italiana -Link- Dimensione File: 491 Kb (502784) Nome autore: Ulrich Krebs eMail autore: -eMail- Sito Web Autore: -Link- Descrizione: calendario per gestire ricorrenze e appuntamenti Multilingua, compreso l'italiano Portable tips how-to: decomprimere il file Kalender_Italian.zip Test effettuato: Ho rilevato solo un errore con i file recenti, cambiando posizione al programma dando l'ok, il file Kalender.ini si aggiorna automaticamente cancellando il percorso memorizzato e si può proseguire con l'utilizzo del software Gli altri percorsi si aggiornano senza problemi. Versione: 2.2.1 Licenza: Freeware | ||
Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12956 | Spostando il programma, il percorso del database viene aggiornato in Kalender.ini e tutti gli eventi vengono mantenuti. C'è qualche problema quando si crea un nuovo database (che deve essere ovviamente salvato all'interno della cartella del programma). Questo viene memorizzato nei recenti e non può essere aperto se non da File/Apri. Se fosse open source si potrebbe portabilizzare, ma é Freeware, quindi non è possibile. Non lo so, io mi astengo. [ Modificato mer 11 mar 2009 - 01:58 ] | ||
Ketty |
Utente registrato #5089 Registrato il: sab 09 giu 2007 - 02:27Messaggi: 1461 | Dico la mia In questo caso per me non è un problema dato che non si perde niente. Per questo ho scritto dando l'ok, il file Kalender.ini si aggiorna automaticamente cancellando il percorso memorizzato e si può proseguire con l'utilizzo del software | ||
