UK's Kalender
icemax
dom 04 feb 2007 - 16:24
Utente registrato #194
Ciao..a tutti
propongo UK's Kalender Ottimo calendario/appuntamenti/ToDo
ottimo sostituto a Essential pim(NON molto stabile)
contro : manca la rubrica (!peccato")
potete scaricarlo da qui :
in italiano: -Link-
home page :http://www.8ung.at/ukrebs/
licenza : assolutamente free
caratteristiche :
What "UK's Kalender" can do
* Automatic saving
Any changes to the database are automatically and immediately saved to disk. On every program start, a backup copy of your data file is created.
* Unlimited Undo and Redo
Most changes can be undone and also repeated.
* Minimize to the system tray
"UK's Kalender" minimizes into the system tray (the area next to the system clock).
* Network support
"UK's Kalender" supports a shared event file, where every user can enter events that'll show up in each other user's calendar. For using the network functions it is neither required to install special server software nor to keep the computer with the shared event file permanently running. "UK's Kalender" will synchronize the local event file as soon as the shared event file is accessible.
* Repeating events
There are lots of possibilities for entering repeating events, e.g. hourly, every three days, monthly, every first tuesday of the month or even every friday the 13th.
* Forewarn time and snooze function
Each event can be assigned a user defined forwarn time in the range from one minute to several weeks. In the reminder dialog you can enter a time after that you'll be reminded again. Alternatively you can choose to be reminded again a certain time before the event.
* Multi day events
Events can have a duration from one minute to several days (or no duration at all, but just a start date).
* Event categories and templates
Events can be organized into categories, e.g. "Doctor", "Meeting", "Party" and so on. Each category is assigned a template of settings, including repetition rate and forewarn time.
* Acoustic reminders
You can choose to be reminded of an event with a WAV file of your choice.
* Event driven program execution and document opening
Documents or programs can be attached to an event. This is very handy for e.g. regular backup purposes.
* Marking and hiding events
Special events may be either color marked or hidden.
* Four event views
Events can be displayed in week-, fortnight-, month- or year-view.
* Tooltips for events and todos
If you stop the mouse over a calendar date or a todo, extended info is shown for the events and todos.
* Alarms can be deativated
Alarms may be deactivated all at once, so your game, film etc. won't be interrupted.
* Highly configurable display for events and todos
All views can easily be configured to present the information just the way you want.
* Search and filter functions
You can search for and filter out your events using keywords, categories, event states or date ranges. The filter function directly affects all output functions, so you can easily create e. g. a calendar only containing birthdays.
* Clipboard support
Events and todos can be copied to the clipboard and may be pasted back to any word processor or "UK's Kalender" itself.
* Export to HTML- and CSV-format
Events and todos can be exported to HTML-format in different views. With this you can easily print your dates and todos. Export to CSV-format allows the transfer of your data to a spreadsheet program. All activated filter options are applied to the output.
* Holidays
Holidays for Gemany, Italy, France, UK, Sweden, Norway, Finland, Czech Republic, Poland, Israel, Canada and the USA can be displayed.
What "UK's Kalender" can't do
* Import and export from or to other calendar programs
"UK's Kalender" has a proprietary file format. Neither does it understand the file format of other applications nor does it support the export of foreign calendar formats.
* Printing
Direct printing from "UK's Kalender" is not supported. Nevertheless you can export all your data into a HTML file and print your calendar from any web browser.
provatelo !
c.i.a.o.
[ Modificato mer 11 mar 2009 - 01:50 ]
mer 11 mar 2009 - 01:17
Utente registrato #5089
Nome del software: UK's Kalender
Direct Link al download: versione italiana -Link-
Dimensione File: 491 Kb (502784)
Nome autore: Ulrich Krebs
eMail autore: -eMail-
Descrizione: calendario per gestire ricorrenze e appuntamenti
Multilingua, compreso l'italiano
Portable tips how-to: decomprimere il file Kalender_Italian.zip
Test effettuato: Ho rilevato solo un errore con i file recenti, cambiando posizione al programma
dando l'ok, il file Kalender.ini si aggiorna automaticamente cancellando il percorso memorizzato e si può proseguire con l'utilizzo del software
Gli altri percorsi si aggiornano senza problemi.
Versione: 2.2.1
Licenza: Freeware
mer 11 mar 2009 - 01:49
Spostando il programma, il percorso del database viene aggiornato in Kalender.ini e tutti gli eventi vengono mantenuti. C'è qualche problema quando si crea un nuovo database (che deve essere ovviamente salvato all'interno della cartella del programma). Questo viene memorizzato nei recenti e non può essere aperto se non da File/Apri. Se fosse open source si potrebbe portabilizzare, ma é Freeware, quindi non è possibile.
Non lo so, io mi astengo.
[ Modificato mer 11 mar 2009 - 01:58 ]
mer 11 mar 2009 - 02:02
Dico la mia
In questo caso per me non è un problema dato che non si perde niente. Per questo ho scritto
