[Search Files] Index Your Files - (Freeware) Vai a pagina >> |
Rafael Castro |
Utente registrato #3303 Registrato il: dom 11 mar 2007 - 19:13Messaggi: 3 | Search Files for Windows with Advanced Features using Index Files. Is portable. Is easy to use with a standard windows GUI. Creates indexes faster and smaller than any other. Compacts the indexes Create indexes for only the directories you select. Internal display for found files Runs from a single file without .dll's Automatically update the indexes at any time selected , or at any regular time , or time interval. -Link- [ Modificato gio 26 mar 2009 - 16:03 ] | ||
icemax |
Utente registrato #194 Registrato il: dom 21 gen 2007 - 22:27Messaggi: 1371 | ottimo .. test portabilità 100% : non sembra scrivere dati sul registro e sulla cartella utente ottima segnalazione | ||
Utente registrato #74 Registrato il: dom 21 gen 2007 - 11:31Provenienza: Tradate (VA) Messaggi: 3821 | Hi Rafael, welcome to our forum! Thank you very much for your suggestion. Personally, I discovered your program last month, during some search about a simple (and freeware, and portable, and...) indexing program. I think that yours offers more than my needings... Compliments! When did you think to publish a new freeware version with more options from the major one (i.e. searching inside files)? Best regards ZioZione | ||
Rafael Castro |
Utente registrato #3303 Registrato il: dom 11 mar 2007 - 19:13Messaggi: 3 | Ahora el versión Revolution busca dentro de los archivos. La revolución es software de libre evaluación. Esperaré un año aproximadamente, si nadie lo comprara, lo convertiré en software gratis. At present the version Revolution searches inside the files. Revolution is shareware. I will expect a year approximately, if nobody buys it, I will turn it into freeware. Siguiente Version Pro! - Busca EXIF Tag y Mp3 Tag ( ( Rapido - Rapido ) ) Next Version Pro! - Search Exif Tag and Mp3 Tag ( (Fast - Fast) ) Screenshot. | ||
Utente registrato #74 Registrato il: dom 21 gen 2007 - 11:31Provenienza: Tradate (VA) Messaggi: 3821 | Rafael Castro ha scritto ... At present the version Revolution searches inside the files. Revolution is shareware. I know it, that's why I asked you... Rafael Castro ha scritto ... I will expect a year approximately, if nobody buys it, I will turn it into freeware. No, I wish you to have a lot of buyers, so you can release version 4 shareware and version 3.2 freeware... Best regards ZioZione | ||
Rafael Castro |
Utente registrato #3303 Registrato il: dom 11 mar 2007 - 19:13Messaggi: 3 | mmm.... is very possible... | ||
Ketty |
Utente registrato #5089 Registrato il: sab 09 giu 2007 - 02:27Messaggi: 1461 | Ziozione spiegazione in italiano -Link- Aggiornamento Versione: v4.0 Alpha16 (Last Update 15 December 2007) -Link- Dimensione: 753 Kb (771072 byte) Decomprimere il file iyf-x.zip, avviare dal file iyf-x.exe Test: nulla da segnalare ma chiedo test di verifica Non presente in Download [ Modificato mar 24 mar 2009 - 16:24 ] | ||
Utente registrato #74 Registrato il: dom 21 gen 2007 - 11:31Provenienza: Tradate (VA) Messaggi: 3821 | Ketty ha scritto ... Ziozione spiegazione in italiano -Link- Aggiornamento Versione: v4.0 Alpha16 (Last Update 15 December 2007) -Link- Dimensione: 753 Kb (771072 byte) Decomprimere il file iyf-x.zip, avviare dal file iyf-x.exe Test: forse mi sfugge qualcosa ma tutti i database che creo, impostano dei percorsi assoluti. Per il resto è portabile. Chiedo test di verifica Non presente in Download Ciao Ketty, da un programma di questa categoria dobbiamo per forza aspettarci che indicizzi i files con il loro path assoluto, altrimenti sarebbe veramente problematico gestire (e trovare) files su più dischi diversi... Quindi i path assoluti (intesi come nomi dei files all'interno del database) ci stanno, eccome... D'altrinde ha poco senso pensare di indicizzare i files su un PC e poi usare il programma per cercare lo stesso file su un altro PC. Le indicizzazioni sono strettamente legate alla singola macchina. Per garantire la portatilità, comunque, si può pensare di creare un database per ogni PC su cui si esegue il programma, in modo da avere comunque una base da cui partire per le ricerche (o per gli aggiornamenti delle indicizzazioni). Se non sono stato chiaro, lo rispiego volentieri Cordialmente ZioZione | ||
Ketty |
Utente registrato #5089 Registrato il: sab 09 giu 2007 - 02:27Messaggi: 1461 | Se ti riferisci a me, sei stato chiarissimo come sempre Anzi, considerato che a volte è un automatismo testare e non ragionare (almeno a me capita) mi sono di grande aiuto le spiegazioni anche se molti le ritengono inutili e scontate. | ||
Ketty |
Utente registrato #5089 Registrato il: sab 09 giu 2007 - 02:27Messaggi: 1461 | Scusa Zio non uccidermi. Il tuo discorso l'ho compreso e mi è stato di aiuto ma ciò che intendevo dire era un'altra cosa. Quindi i path assoluti (intesi come nomi dei files all'interno del database) ci stanno, eccome... D'altrinde ha poco senso pensare di indicizzare i files su un PC e poi usare il programma per cercare lo stesso file su un altro PC. Le indicizzazioni sono strettamente legate alla singola macchina. Ho il programma sul drive H, ho creato un database di nome Ketty (per non confonderci con le lettere). Sposto il programma sul drive G, lui cerca il database "ketty" sul drive H. Quindi ogni volta che cambio drive sullo stesso pc è da aggiornare il percorso del database creato, non parlavo dei file da analizzare che ovviamente riguardano un determinato pc. [ Modificato sab 21 mar 2009 - 23:14 ] | ||
