[GRAFICA] IcoFX 1.5 - freeware
icemax
ven 01 giu 2007 - 20:24
Utente registrato #194
Nome del software: IcoFX
Pagina download: -Link-
Dimensione File: 2,44 MB (2.562.683 byte) [ decompresso con UE]
Nome autore: nd
eMail autore: -nd
Descrizione: IcoFx free icon editor per Windows XP e Windows Vista.
IcoFx include moltissimi tools ed effetti per l'editing e la manipolazione di icone.
IcoFx crea, importa esporta trasforma qualsiasi tipo di icone , e mostra una bellissima e funzionale interfaccia.
Portable tips how-to: versione portatile da scaricare dalla pagina di download
Versione: Version 1.5
Licenza: Freeware
Screenshots:
info originali :
Features of IcoFX
Support for Vista icons with PNG compression
Create icons for Windows 98 / ME / 2000 / XP / Vista
Support for alpha channel
New: Batch processing
More than 40 effects, including Drop Shadow
Create custom filters
New: Multiple language support (Available translations: Catalan, English, German, Hungarian, Japanese, Romanian and Spanish)
Resolutions up to 256x256
Data types: 2, 16, 256, True Color, True Color + Alpha
Extract icons (including Vista icons) from 32 bit exe and dll
Import / export images (transparency also)
Many useful drawing tools like brush, line, rectangle and more
Transparent, Brighten/Darken, Blur/Sharpen tools for retouching
Create icon from an image with a single click
Adjust the contrast, brightness, hue, saturation, transparency and color balance of icons
Change the dimension of images
New: Images can be faded using the fadeout dialog
Increase / decrease the opacity of an image
New: Easy shadow handling
RGB and HSB color modes
New: History of recently opened files
New: Window menu for easy window switching
Possibility to store favorite colors
Capture image from the desktop
Grid for precision work
New: Side bar for easy image switching
New: File Explorer window for easy import
New: Full drag and drop support
Sizable preview window
Multiple undo
Blur the edge of the brush
Rotate the image at any angle
[Scheda aggiornata]
[ Modificato lun 09 lug 2007 - 01:42 ]
ven 01 giu 2007 - 20:31
Scusa Icemax, ma la cartella in Dati Applicazioni a cui hai dato l'1% di responsabilità, ne merita almeno il 99%, dato che contiene le impostazioni del programma.
Quindi, a meno di chiedere un'autorizzazione all'autore per la portatilizzazione, NON E' PORTATILE.
icemax
sab 02 giu 2007 - 10:20
ho inviato una email riguardo al launcher , per portabilizzarlo
attendo risposte
[ Modificato sab 02 giu 2007 - 10:21 ]
icemax
sab 02 giu 2007 - 12:19
a tempo record :
VERSIONE PORTATILE
Email originale :
Hello,
Thank you for your interest in my software. IcoFX has already a portable version, so there is no need for this workaround.
This portable version stores all its settings in its installation folder.
You can download IcoFX Portable Edition from -Link-
Best regards,
Attila Kovrig
quindi il link modificato per la versione portatile :
-Link- o più esattamente il link
- al file (ZIP) : -Link- e ...
- alla lingua :
Italian v1.2 - Translation by Giacomo Margarito -Link-
Italiano v1.2 - Alternative translation by Pispolino -Link-
all'Help file : Italiano v1.0 - Translation by Pispolino -Link-
una info per Danix :
errore in upload del file : [ecco il log]
Caricato 'IcoFX.rar'
Caricato 'error.jpg'
Il file eccede i limiti massimi consentiti. Eliminato.
[dimensione del software pack : 1,28 MB
pensaci tu .. fratello
ciaus .. e_state contenti
[ Modificato sab 02 giu 2007 - 12:40 ]
sab 02 giu 2007 - 12:34
Il programma è interessante.
Ma lo hai testato per vedere se è portatile?
Molti autori pubblicizzano versioni portatili dei loro programmi (vedi deepburner) che di portatile hanno solo il nome..
Chiedigli l'autorizzazione all'inserimento nei wPPs
Hai inviato l'eMail concordata, vero?
E poi, per piacere, inseriscilo in Upload. Grazie.
[ Modificato sab 02 giu 2007 - 12:41 ]
icemax
sab 02 giu 2007 - 12:50
ehm.....
esattamente crea [All'interno del programma ] una cartella IcoFX con all'interno il file di configurazione : config.cfg
config.cfg example :
MainForm]
Top=0
Left=0
Height=480
Width=640
Maximized=1
ToolbarVisible=1
LocalToolbarVisible=1
StatusbarVisible=1
SidebarVisible=1
[ToolsForm]
Visible=1
Top=226
Left=793
[ColorsForm]
Visible=1
Top=226
Left=853
ShowRGB=1
ForeColorRed=0
ForeColorGreen=0
ForeColorBlue=0
ForeColorAlpha=255
BackColorRed=0
BackColorGreen=0
BackColorBlue=0
BackColorAlpha=0
FavoritColorPosition=0
[PrevForm]
Visible=1
Top=56
Left=793
Height=170
Width=231
[ExplorerForm]
Visible=0
Top=56
Left=0
Width=244
Height=552
TreeHeight=176
ThumbSize=100
ShowLabel=0
[Grid]
Visible=0
ColorRed=192
ColorGreen=192
ColorBlue=192
Style=2
[General]
BKSize=4
Color1Red=255
Color1Green=255
Color1Blue=255
Color2Red=235
Color2Green=235
Color2Blue=235
PaletteAction=0
ClipboardAction=1
NewIcon=0
SelectedIndex=2
PrevColorRed=255
PrevColorGreen=255
PrevColorBlue=255
Compress=1
FilterOnAlpha=1
SmoothEdges=0
KeepAspectRatio=1
ClearClipboard=1
Language=Italiano
ExportAlpha=1
TransparentSelection=1
AllowDragAndDrop=1
RecentFile1=D:\Documenti\regshot.exe
RecentFile2=
RecentFile3=
RecentFile4=
RecentFile5=
RecentFile6=
RecentFile7=
RecentFile8=
RecentFile9=
RecentFile10=
va bene così .... ..o continuo .... fratello
... sto aspettando l'email per l'autorizzazione all'inserimento nel pack
in riferimento all'upload del file :
[ Modificato sab 02 giu 2007 - 12:52 ]
sab 02 giu 2007 - 12:54
File remoto icemax, non reale.
Dato che, come ben sappiamo, le licenze non permettono di hostare files non GPL.
Leggi qui, se ancora non l'hai fatto
Non ci penso io.
Grazie.
[ Modificato sab 02 giu 2007 - 12:56 ]
mar 05 giu 2007 - 13:08
Il link al download non è più valido.
Icemax,puoi chiedere all'autore se il link all'edizione portatile è stato rimosso, o se era solo per winPenpack? E in questo caso come dobbiamo comportarci (dato che io non me lo ritrovo.... )
sab 09 giu 2007 - 15:40
Utente registrato #9
Provenienza: Veglie
Questo è il link alla versione portatile
A quanto mi risulta, funziona.
Rettifico, funziona, ma solo se ci si collega dal sito ufficiale. Non sono premessi link diretti da siti esterni.
Al massimo, fate un bel copia e incolla deel'indirizzo nell barra del browser e funziona.
[ Modificato sab 09 giu 2007 - 15:42 ]
lun 31 mar 2008 - 17:49
Provenienza: Veglie
Aggiornato alla versione 1.6.
Al contrario della precedente, questa è DEL TUTTO portatile.
Da questa versione in poi (si spera), la traduzione italiana è a cura di Massimo Pizzolante Leuzzi (traduttore, tra gli altri, di ISTool, il wizard per la creazione dei setup con InnoSetup, e GetRight).
[ Modificato sab 12 apr 2008 - 21:33 ]
