Problem with file association
zbyszek
dom 09 mag 2010 - 10:56
Utente registrato #38709
Registrato il: dom 09 mag 2010 - 10:33
So i have many portable apps ... eariel i used other portable menu and all was fine with my file association ... i only click some file choose "Open With" and choose some portable app.
After Using winPenPack menu all my associations was gone... i can't use "Open With" to open via my portable software like earlier ... even i cant submit portable apps to "OpenWithList" in my operating system.
X-Cafe doesen't work porbably because i using other scripts writing in Autohotkey.
So how undo changes made by winPenPack in my file association ?
[ Modificato dom 09 mag 2010 - 13:00 ]
dom 09 mag 2010 - 12:58
zbyszek ha scritto ...
Because C.A.F.E. (and therefore also the modified version distributed in X-Software format, X-Cafe) allows the temporary creation of file associations, no changes are made neither by winPenPack nor by X-Cafe. Just close X-Cafe from system tray.
More details here -Link-
[ Modificato dom 09 mag 2010 - 13:31 ]
zbyszek
dom 09 mag 2010 - 13:12
I removed WPP and all his components (X-Cafe too) from my system but i have stilll the same problem ... i think my OS is crashed ... i will need to make re-formatting ;x
dom 09 mag 2010 - 13:30
As I said, X-Cafe does not integrate into the system, then the reason of your problems should be another.
zbyszek
dom 09 mag 2010 - 13:43
Ok if not integrate into the system then problem is on my side ... thanks for quick answers...
