X-Firefox 3.66 plugin. Thanks. |
| dlusera |
![]() ![]() Utente registrato #39104 Registrato il: ven 09 lug 2010 - 12:38Messaggi: 37 | I want to install Portable plugin on X-Firefox. I not want install to my computer. how can do it ? such as, 1.Java 2.Flash 3.Rmvb , real audio, real movie. Any ideal make portable plugin ? Thanks. | ||
| JCL |
![]() ![]() Utente registrato #39110 Registrato il: sab 10 lug 2010 - 12:54Provenienza: Vienna, Austria Messaggi: 20 | Hi - something in this directon ... I tryed to install a plugin on firefox ( flash player - or something like that ) on my Memory-Stick and the reply was " can't install because there is a newer version already installed in the system " --> means win7. hope someone has a hint ? [ Modificato gio 15 lug 2010 - 11:39 ] | ||
![]() ![]() ![]() Utente registrato #74 Registrato il: dom 21 gen 2007 - 11:31Provenienza: Tradate (VA) Messaggi: 3821 ![]() | Hi dlusera, hi JCL, this question has been already answered (in italian forum only, sorry... )In a few words: is enough to copy the plugins under "Lib\Mozilla\Plugins" folder. Here there are some plugins installable is a such manner: - np32dsw.dll (shockwave director) - NPSWF32.dll (shockwave flash - need also ShockwavePlugin.class file) - nppdf32.dll (adobe acrobat) - np-mswmp.dll (Microsoft® Windows Media Player Firefox Plugin) - npjp2.dll (JPEG2000 image viewer) As you can see here -Link- from rev13, X-Firefox can use Java "portable" in $Lib\Java folder (see packs structure for more informations)Here -Link- -Link- there are also some useful links that depict in details this task (for Flash only), but I think that could be extended with minor differences also to the others.Hope this helps. Best Regards ZioZione | ||
| dlusera |
![]() ![]() Utente registrato #39104 Registrato il: ven 09 lug 2010 - 12:38Messaggi: 37 | Where can I download this following portabe plugin ? Thanks. - np32dsw.dll (shockwave director) - NPSWF32.dll (shockwave flash - need also ShockwavePlugin.class file) - nppdf32.dll (adobe acrobat) - np-mswmp.dll (Microsoft® Windows Media Player Firefox Plugin) - npjp2.dll (JPEG2000 image viewer) ================ ZioZione ha scritto ... Hi dlusera, hi JCL, this question has been already answered (in italian forum only, sorry... )In a few words: is enough to copy the plugins under "Lib\Mozilla\Plugins" folder. Here there are some plugins installable is a such manner: - np32dsw.dll (shockwave director) - NPSWF32.dll (shockwave flash - need also ShockwavePlugin.class file) - nppdf32.dll (adobe acrobat) - np-mswmp.dll (Microsoft® Windows Media Player Firefox Plugin) - npjp2.dll (JPEG2000 image viewer) As you can see here -Link- from rev13, X-Firefox can use Java "portable" in $Lib\Java folder (see packs structure for more informations)Here -Link- -Link- there are also some useful links that depict in details this task (for Flash only), but I think that could be extended with minor differences also to the others.Hope this helps. Best Regards ZioZione | ||
![]() ![]() ![]() Utente registrato #74 Registrato il: dom 21 gen 2007 - 11:31Provenienza: Tradate (VA) Messaggi: 3821 ![]() | dlusera ha scritto ... Where can I download this following portabe plugin ? Thanks. - np32dsw.dll (shockwave director) - NPSWF32.dll (shockwave flash - need also ShockwavePlugin.class file) - nppdf32.dll (adobe acrobat) - np-mswmp.dll (Microsoft® Windows Media Player Firefox Plugin) - npjp2.dll (JPEG2000 image viewer) Hi dsusera, the easiest way is to search them separately one by one with google... Best Regards ZioZione | ||
| dlusera |
![]() ![]() Utente registrato #39104 Registrato il: ven 09 lug 2010 - 12:38Messaggi: 37 | Thanks. But I worry virus and where I got new version ? Can help search for me ? Thanks Again. ZioZione ha scritto ... dlusera ha scritto ... Where can I download this following portabe plugin ? Thanks. - np32dsw.dll (shockwave director) - NPSWF32.dll (shockwave flash - need also ShockwavePlugin.class file) - nppdf32.dll (adobe acrobat) - np-mswmp.dll (Microsoft® Windows Media Player Firefox Plugin) - npjp2.dll (JPEG2000 image viewer) Hi dsusera, the easiest way is to search them separately one by one with google... Best Regards ZioZione | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | dlusera ha scritto ... Thanks. But I worry virus and where I got new version ? Can help search for me ? Thanks Again. This means that you never made a search on Google because you worry viruses? ![]() | ||
| dlusera |
![]() ![]() Utente registrato #39104 Registrato il: ven 09 lug 2010 - 12:38Messaggi: 37 | I already try. 1. I don't wihch version is suitable and news (Many dll file same file name), 2.virus problems. So , I hope has some one can tell me the download site or upload for me. Many Thanks. Danix ha scritto ... dlusera ha scritto ... Thanks. But I worry virus and where I got new version ? Can help search for me ? Thanks Again. This means that you never made a search on Google because you worry viruses? | ||
