X-Firefox 3.66 plugin. Thanks.
dlusera
Thu 15 Jul 2010 - 10:29
Registered Member #39104
I want to install Portable plugin on X-Firefox. I not want install to my computer. how can do it ? such as,
1.Java
2.Flash
3.Rmvb , real audio, real movie.
Any ideal make portable plugin ?
Thanks.
JCL
Thu 15 Jul 2010 - 11:38
Registered Member #39110
Hi - something in this directon ...
I tryed to install a plugin on firefox ( flash player - or something like that ) on my Memory-Stick and the reply was " can't install because there is a newer version already installed in the system " --> means win7.
hope someone has a hint ?
[ Edited Thu 15 Jul 2010 - 11:39 ]
Thu 15 Jul 2010 - 12:23
Registered Member #74
Hi dlusera, hi JCL,
this question has been already answered (in italian forum only, sorry... )
In a few words: is enough to copy the plugins under "Lib\Mozilla\Plugins" folder.
Here there are some plugins installable is a such manner:
- np32dsw.dll (shockwave director)
- NPSWF32.dll (shockwave flash - need also ShockwavePlugin.class file)
- nppdf32.dll (adobe acrobat)
- np-mswmp.dll (Microsoft® Windows Media Player Firefox Plugin)
- npjp2.dll (JPEG2000 image viewer)
As you can see here -Link- from rev13, X-Firefox can use Java "portable" in $Lib\Java folder (see packs structure for more informations)
Here -Link- -Link- there are also some useful links that depict in details this task (for Flash only), but I think that could be extended with minor differences also to the others.
Hope this helps.
Best Regards
dlusera
Fri 16 Jul 2010 - 12:21
Where can I download this following portabe plugin ? Thanks.
ZioZione wrote ...
Hi dlusera, hi JCL,
Hope this helps.
Best Regards
Fri 16 Jul 2010 - 13:29
dlusera wrote ...
Hi dsusera,
the easiest way is to search them separately one by one with google...
Best Regards
dlusera
Sun 18 Jul 2010 - 06:46
Thanks. But I worry virus and where I got new version ? Can help search for me ? Thanks Again.
ZioZione wrote ...
dlusera wrote ...
Hi dsusera,
Best Regards
Sun 18 Jul 2010 - 20:08
dlusera wrote ...
This means that you never made a search on Google because you worry viruses?
dlusera
Mon 19 Jul 2010 - 07:45
I already try. 1. I don't wihch version is suitable and news (Many dll file same file name), 2.virus problems. So , I hope has some one can tell me the download site or upload for me. Many Thanks.
dlusera wrote ...
