Problem with file association in X-Cafe |
dropper |
Utente registrato #39636 Registrato il: mar 15 feb 2011 - 23:47Messaggi: 165 | I have integrated the program X-Cafe into winPenPack Launcher 1.4.1.190. Afterwards I have installed the native portable program PDF-XChange Viewer. According to the instructions under Nr. 10 of the X-Cafe documentation I have tried to change the file association for the PDF format. The former entry was: .. \ SumatraPDF \ SumatraPDF.exe After my change was the new entry: .. \ PDF-XChange Viewer \ PDFXCview.exe After the close and restart of the launcher, however, was the change in X-Cafe reversed and the old entry (.. \ SumatraPDF \ SumatraPDF.exe) reappeared. What is the cause of this problem and how can I fix it? | ||
dropper |
Utente registrato #39636 Registrato il: mar 15 feb 2011 - 23:47Messaggi: 165 | In the meantime I could solve my problem myself, which I have described in the original post. However, it is now a new problem surfaced. After I started to open the winPenPack Launcher, a PDF document should be opened by double clicking with the program PDF-Xchange Viewer. Unfortunately, at the first double click (immediately after a new boot of the computer) the program Adobe Reader X started. After I closed the Adobe Reader X, the second double click started the program PDF-XChange Viewer. How can this error resolved, so that the program PDF-XChange Viewer is used at the first double click? [ Modificato dom 05 giu 2011 - 10:32 ] | ||
