x-firefox 3.22 and 6.02 found 2 bugs. thanks. |
dlusera |
Utente registrato #39104 Registrato il: ven 09 lug 2010 - 12:38Messaggi: 37 | I tested x-firefox 3.22 and 6.02 found 2 bugs : 1. I already rem or delete this following x-firefox.Ini (I already tested rem 1, 1+2, 1+2+3 lines, delete all 4 lines): ;(download directory) ;browser.download.lastDir=$Download$|\\" ;browser.download.dir=$Download$|\\" browser.download.folderList=2 When I next time or restart firefox save location also on X-firefox folder (X-Firefox\download\) , that not remember my before save location (such as D:\temp) 2. I used reminder fox plugin on x-firefox. I open the 'reminder fox plugin' window, but when I closed the X-firefox, 'reminder fox plugin' window not close. Thanks. hope can Fix it 2 bugs. | ||
Utente registrato #251 Registrato il: lun 22 gen 2007 - 10:12Provenienza: Buttrio (UD) Messaggi: 3358 | Tested here few minutes ago. NO ISSUES AT ALL!! Tested on: win7 pro 64 bit SP X-Firefox version: 6.02 actions made: 1 ) Installed Reminderfox 2 ) closed X-Firefox 3 ) started again 4 ) Put some reminders in Reminderfox 5 ) Closed X-Firefox -> EVERYTHING shut-down properly Impossible to reproduce Your problem. Then, after CLOSING my X-Firefox 1 ) edited firefox.ini file (COPY/PASTE from my ini) ;(download directory) ;browser.download.lastDir=$Download$|\\" ;browser.download.dir=$Download$|\\" ;browser.download.folderList=2 (end COPY/PASTE) 2 ) started again X-Firefox 3 ) changed settings in "Options" -> "General" -> and pointed on "Always ask where to save download files" (or something like that... my X-Firefox is in italian! ) 4 ) tested with different downloads. Program asks me each time where I want to save. 5 ) Closed X-Firefox 6 ) Tested DL feature again -> everything works as per my settings 7 ) changed setting in "Options" -> "General" -> and pointed on "Save files in.." and set my perdsonal path. 8 ) Tested DL again -> program saves correctly in my personal path 9 ) Closed X-Firefox 10) Tested DL feature again -> everything works as per my last settings So, I'm not able al all to reproduce your "pseudo.bugs" ! Dlusera, are you sure to have X-firefox CLOSED when you edit firefox.ini? [ Modificato mar 20 set 2011 - 11:54 ] | ||
dlusera |
Utente registrato #39104 Registrato il: ven 09 lug 2010 - 12:38Messaggi: 37 | 1. I mean don't want longer remember the 'path', I just want remeber the 'last save path'. for examples last I save remember D:\temp , and some time may E:\temp\ ... I mean 'last save'. 2. 1. start--->firefox 2 tool--->reminderfox--->reminderfox(show the reminderfox windows) 3. direct closed firefox. (don't close the reminderfox windows) sorry my bad english. support please test too. thanks. [ Modificato mar 20 set 2011 - 14:35 ] | ||
dropper |
Utente registrato #39636 Registrato il: mar 15 feb 2011 - 23:47Messaggi: 165 | Basically there are two variants to arrange the download settings in Firefox.
For your problem with ReminderFox I can't give you an answer, because I don't use this extension. [ Modificato mar 20 set 2011 - 15:17 ] | ||
