Link sponsorizzati
Portability of Tomahawk PDF+
dropper
gio 12 gen 2012 - 12:08
Utente registrato #39636
Registrato il: mar 15 feb 2011 - 23:47
I have carefully read the article by developer Taf, in which he described the method in order to make it completely portable.
By default after the creation of a PDF-file with Tomahawk PDF+ will be opened the Adobe Reader on the host PC (For this case I assume, that the Adobe Reader is installed on the host PC). Unfortunately this will generates some registry keys, which are associated with the Adobe Reader.
HKU\S-1-5-21-1960408961-1532298954-682003330-1004\Software\Adobe\Acrobat Reader\9.0\AVGeneral\cRecentFiles\c2
HKU\S-1-5-21-1960408961-1532298954-682003330-1004\Software\Adobe\Acrobat Reader\9.0\RememberedViews\cNoCategoryFiles\c2
HKU\S-1-5-21-1960408961-1532298954-682003330-1004\Software\Adobe\Acrobat Reader\9.0\RememberedViews\cNoCategoryFiles\c2\cViewDef
HKU\S-1-5-21-1960408961-1532298954-682003330-1004\Software\Adobe\Acrobat Reader\9.0\RememberedViews\cNoCategoryFiles\c2\cViewDef\cBottomView
HKU\S-1-5-21-1960408961-1532298954-682003330-1004\Software\Adobe\Acrobat Reader\9.0\RememberedViews\cNoCategoryFiles\c2\cViewDef\cLeftView
HKU\S-1-5-21-1960408961-1532298954-682003330-1004\Software\Adobe\Acrobat Reader\9.0\RememberedViews\cNoCategoryFiles\c2\cViewDef\cocgStates
HKU\S-1-5-21-1960408961-1532298954-682003330-1004\Software\Adobe\Acrobat Reader\9.0\RememberedViews\cNoCategoryFiles\c2\cViewDef\cTopLeftView
HKU\S-1-5-21-1960408961-1532298954-682003330-1004\Software\Adobe\Acrobat Reader\9.0\RememberedViews\cNoCategoryFiles\c2\cViewDef\cTopLeftView\cocgStates
To avoid these entries, I have customized the file TPdfPlus.ini contained in the folder X-Tomahawk\User\TomahawkPDF. This file should contain the following code:
[PDF]
PageSize=0
Orientation=0
PageMode=0
Layout=1
Version=1
Embedding=2
Author=
AutoLaunch=0
In particular is achieved by the entry "AutoLaunch=0", that in the dialog window titled "Tomahawk Pdf Creator" the checkbox named "Launch Acrobat Reader after creation" is disabled. This dialog window can be opened about File -> Convert to Pdf.
Accordingly, the user should be cautioned not to activate this checkbox.
