dlusera |
![]() ![]() Utente registrato #39104 Registrato il: ven 09 lug 2010 - 12:38Messaggi: 37 | everytime I run X-firefox 11.0 Rev5. must listen the sound 'peep' and the x-firefox popup the info on the traybar. how can I disable this problems ? before version, I not has this problems. user known the winpen website and always support it . I think not need special tell the user info. hope can let user choice enabled and disable. other portable ware also not do this adv. thanks again. | ||
![]() ![]() ![]() ![]() Utente registrato #3184 Registrato il: mar 06 mar 2007 - 11:52Provenienza: Busto Arsizio Messaggi: 3301 ![]() | Hi dlusera, the 'popup' is a function introduced in the new launcher 1.5.0; the "beep" sound is not intentional, it depends on the windows settings (mine OS are always setted to mute, so I havent noticed) . To disable it, you can edit x-firefox.ini and change the option "ShowTrayTip" from true to false. Instead, if you have a pack, you can disable the popup for all softwares in the pack editing the file XDrive\X-Launcher.cfg adding this lines: [Options] ShowTrayTip=false Hope this help you ![]() | ||
