Error during X-Firefox installation |
| Siffrediano |
![]() ![]() Utente registrato #40686 Registrato il: ven 07 set 2012 - 15:47Messaggi: 1 | Dear sirs:i downloaded x-chromium and x-iron(from sourceforge)and they work very fine.However,when i download any version of x-firefox and want to run the installer to build the program it simple doesn't work,doesn't run because it says in two windows["incorrect remote setup link" and "x-firefox.exe-Error during first run operations-Please retry"].I don't know what's happening!!Please,try to fix the problem,ok?Thank you very much and a hug to the team-Fernando Carvalho(Portugal). | ||
| zandet2 |
![]() ![]() ![]() Utente registrato #3184 Registrato il: mar 06 mar 2007 - 11:52Provenienza: Busto Arsizio Messaggi: 3301 ![]() | Siffrediano ha scritto ... Dear sirs:i downloaded x-chromium and x-iron(from sourceforge)and they work very fine.However,when i download any version of x-firefox and want to run the installer to build the program it simple doesn't work,doesn't run because it says in two windows["incorrect remote setup link" and "x-firefox.exe-Error during first run operations-Please retry"].I don't know what's happening!!Please,try to fix the problem,ok?Thank you very much and a hug to the team-Fernando Carvalho(Portugal). Hi Siffrediano/Fernando, first of all This is the same problem reported by the user robby -Link- , but the discussion was in italian:simply, the 15.0 version was removed from the mirror server to be substituted with the 15.0.1, so the launcher cannot find the setup. Anyhow, now is available the X-Firefox 15.0.1 release, just download it to solve the problem. Thank you! | ||
