Extraction of the file picpick_inst.exe doesn't work |
| dropper |
![]() ![]() Utente registrato #39636 Registrato il: mar 15 feb 2011 - 23:47Messaggi: 165 | I tried to extract the file picpick_inst.exe (regarding the new version 3.1.8) with X-UniExtract 1.6.1 [rev4]. Unfortunately without any success. The extracted file picpick.exe is damaged. In contrast, extracting work fine with X- 7zip. Has anyone an idea, why the extraction doesn't work with X-UniExtract 1.6.1 [rev4]? | ||
| zandet2 |
![]() ![]() ![]() Utente registrato #3184 Registrato il: mar 06 mar 2007 - 11:52Provenienza: Busto Arsizio Messaggi: 3301 ![]() | dropper ha scritto ... I tried to extract the file picpick_inst.exe (regarding the new version 3.1.8) with X-UniExtract 1.6.1 [rev4]. Unfortunately without any success. The extracted file picpick.exe is damaged. In contrast, extracting work fine with X- 7zip. Has anyone an idea, why the extraction doesn't work with X-UniExtract 1.6.1 [rev4]? Hi dropper, the extracion of PicPick fail because X-UniExtract is bundled with an old version of 7zip extractor (9.13); that's why if you use X-7Zip directly, that is updated at 9.22 version, the extraction is successfull. | ||
| dropper |
![]() ![]() Utente registrato #39636 Registrato il: mar 15 feb 2011 - 23:47Messaggi: 165 | Thanks for your explanation. Is it therefore sufficient, if I replace the old file 7z.exe (version 9.13) with the latest file 7z.exe (version 9.22) within the folder winpenpack\Bin\Uniextract\bin. But I found in this folder another file 7z.dll. Must I also replace this file? | ||
| zandet2 |
![]() ![]() ![]() Utente registrato #3184 Registrato il: mar 06 mar 2007 - 11:52Provenienza: Busto Arsizio Messaggi: 3301 ![]() | dropper ha scritto ... Thanks for your explanation. Is it therefore sufficient, if I replace the old file 7z.exe (version 9.13) with the latest file 7z.exe (version 9.22) within the folder winpenpack\Bin\Uniextract\bin. But I found in this folder another file 7z.dll. Must I also replace this file? Yes, you have to replace both. Anyhow, I'm planning to pack a new version of X-UniExtract updating the outdated softwares, not only 7zip but also upx, lzop and so on. | ||
