win PenPack Upgrade Manager doesn't work correctly |
| dropper |
![]() ![]() Utente registrato #39636 Registrato il: mar 15 feb 2011 - 23:47Messaggi: 165 | In the past I have sometimes recognized, that the win PenPack upgrade manager returns false indications. For example after installing the latest version X-Gimp 2.8.2 [rev22] me the following appears: Current Version: 2.8.2 New Version: 2.8.0 That's obviously a failure. [ Modificato mar 25 set 2012 - 11:39 ] | ||
| zandet2 |
![]() ![]() ![]() Utente registrato #3184 Registrato il: mar 06 mar 2007 - 11:52Provenienza: Busto Arsizio Messaggi: 3301 ![]() | dropper ha scritto ... In the past I have sometimes recognized, that the win PenPack upgrade manager returns false indications. For example after installing the latest version X-Gimp 2.8.2 [rev22] me the following appears: Current Version: 2.8.2 New Version: 2.8.0 That's obviously a failure. Hi dropper, could you try again now the update check? Thank you | ||
| dropper |
![]() ![]() Utente registrato #39636 Registrato il: mar 15 feb 2011 - 23:47Messaggi: 165 | Now the Upgrade Manager works fine. Thank you. But what was the reason for this failure? [ Modificato mar 25 set 2012 - 12:16 ] | ||
| zandet2 |
![]() ![]() ![]() Utente registrato #3184 Registrato il: mar 06 mar 2007 - 11:52Provenienza: Busto Arsizio Messaggi: 3301 ![]() | dropper ha scritto ... Now the Upgrade Manager works fine. Thank you. But what was the reason for this failure? I haven't regenerated the list used by UpdateManager after publishing X-Gimp; now the list is updated. Thank you | ||
