win PenPack Upgrade Manager doesn't work correctly
dropper
mar 25 set 2012 - 11:35
Utente registrato #39636
Registrato il: mar 15 feb 2011 - 23:47
In the past I have sometimes recognized, that the win PenPack upgrade manager returns false indications. For example after installing the latest version X-Gimp 2.8.2 [rev22] me the following appears:
Current Version: 2.8.2
New Version: 2.8.0
That's obviously a failure.
[ Modificato mar 25 set 2012 - 11:39 ]
mar 25 set 2012 - 12:12
dropper ha scritto ...
New Version: 2.8.0
Hi dropper,
could you try again now the update check?
Thank you
dropper
mar 25 set 2012 - 12:15
Now the Upgrade Manager works fine. Thank you. But what was the reason for this failure?
[ Modificato mar 25 set 2012 - 12:16 ]
mar 25 set 2012 - 12:33
I haven't regenerated the list used by UpdateManager after publishing X-Gimp; now the list is updated.
Thank you
